Hi! This is my first post and please bear my ignorance as I just got my 1400. So, I have installed the Precision Colors dye ink (not CIS) and re-routeed the waste ink to ext bottle. Everything is working fine but as been said before, this printer drinks ink. I have noticed how much ink is being deposited in the ext bottle and makes me wonder, should I just leave the printer on and let it sleep (1.2Watt?), or should I turn it off (0.2Watt?) when not being used. Is the print head parked the same either way? My Brother MFC will self-clean so clogging is never an issue. Does 1400 do that? The puzzling part is that the printer doesn't seem to clean the nozzle every time being turned on, just some times, and I have not figured out a pattern.
I have been profiling (Spyder3Print) with a few glossy papers that I have and "Ultra Premium Photo Paper Glossy / Photo RPM" seems to work best. Some old Fujifilm Premium plus Glossy 250gsm swellable papers have serious puddling issue with this printer when not using "Photo RPM" which helps a lot but still puddles slightly with some darker colours but this is as slow as I can make it to print. When doing alignment, it becomes clear the paper is unable to absorb bigger drops of ink and bleed (like non-RPM mode). Also, I have found this issue is greatly affected by room temperature. If it drops below 20C, it can be quite bad. Maybe that's the reason swellable papers are being phased out? Can swellable paper age?
Also, anyone using Canon PP-201 (Plus II) or PT-101 (Pro Platinum) papers with this printer. How are they compared and any extra tips on using this printer? My biggest concern is fade resistance but I do like glossy and don't print often enough to justify expensive pigment printer, or run the 1400 with pigment ink which is said to clog more often if left unused. These 2 papers are on special right now and I might stock them up if they don't age like swellable with good fade resistance with dye (I know that's not ideal). Any advice is appreciated.
