Discussion on linux support for the epson sc-P900, drivers, print quality
taco-fever
Epson SC-P900
I got my hands on an epson sc-P900, and I'm working exclusively on linux, with darktable. And I'm a bit lost in how to proceed to actually use my printer on linux.
I want to use it mostly for photography print on fine art papers. I also want to be able to calibrate the printer and get accurate colours relatively to my calibrated monitor. I'm not by any mean a color expert, but I really like to understand how things work, and from the artistic point of view, more way to control the printer is also more way to better convey the emotions in a photograph.
As a my participation to the community, I tried to gather in this post all information I got about linux use of the P900 !
Here are the options I came across:​
The gutenprint driver, turboprint, and Airprint and/or IPP. I also head somewhere that espon linux driver have undocumented support for the P900, but I have no more info on that.
TURBOPRINT:​
Support the P900, and icc profiles. Some people complain about the software stability. It seems to be a high quality driver, but I have not seen quantitative information on that.
It is often said that Turboprint is cheap, but for this printer, Turboprint driver is quite expensive, as you have to add the studio XL option ( 179,95€ in total), and I would much rather not having to pay that much just to use the printer, if I don't need to. It is great that turboprint exist, but personnally, I would rather spend my money on paper and ink for the open source community.
GUTENPRINT:​
Support icc profiles, from what I read, by including them in the file.
Gutenprint current support for the P900 is incomplete (based on the P800 which has a different resolution, number of ink, and matte/glossy black handling), here is a summary of the discussions I came accross in the gimp-print mailing list. It seems that quite a few people would be interested in gutenprint to support the P900. I hope these information can help someone along he path:
discussion on how the printer select matte /glossy ink and violet channel.
Seems rather technical, as it involves reverse engeneering the official driver
discussion on ESCP/R vs escp/2
P900 seems to support escp/2, but the official driver uses escp/R
code for violet new ink, and matte black ink
Air print vs gutenprint discussion
In particular, any new escp2 commands ?
if you genuinely do need Gutenprint's feature set, adding support will take either direct physical access or someone willing to do the necessary legwork, and will require expending a decent amount of ink before the quality will be considered usable.
If that's not good enough, and you need Gutenprint's feature set, I'd
expect getting the printer working will be straightforward (specs imply
ESC/P2, 10 ink channels, 180 nozzles per), but in that ink set there's a
new violet ink that would need to be added to gutenprint, and of course
a decent amount of ink would need to be expended to tune the overall
output until it's of sufficient quality.
But as an example, when I added in the Epson SL-D700 (roll-fed, 6-color
inkset) about two years ago, I produced over 100 6x8" prints before the
print quality was considered "good enough" for client -- and there was
still a lot of work remaining for the remaining quality+paper
combinations.
The main differences are a new ink set and support for a higher
resolution mode.
If that appears to mostly work, then you'll need to create a set of XML
data files for the inkset and underlying model, this commit (for the
SL-D700) shows what's needed:
597efe256b6e0ea8ffc48d780371cd67983a4e4c
Maybe prefer airprint ?
AIRPRINT/IPP:​
I haven't been able to find much information on how to use airprint with the P900, what set of features it supports. I haven't found anything on calibration and color management, print resolution/quality.
My questions:​
Driver quality comparison:​
I'm trying to get an understanding on how these different ways of using the printer impact the quality of prints, and how much control over the printer they offer.
Correct me if I'm wrong, but from what I understood now, gutenprint and turboprint are actual drivers, controlling directly the printing heads through escp commands. They both take rgb images and perform the required dithering process, and offer high resolution printing (through waving). They both offer a option to print without color management so calibration is possible.
I could not find much documentation on how airprint is actually implemented by epson, but I'm guessing that, as opposed to the other two, the driver is embed in the printer itself, and the printer is doing the processing to convert the rgb image to printer commands. I guess it implies less control, and less quality because printer has less compute power than a computer. Otherwise, epson wouldn't provide a windows driver.
But I haven't seen any "real" comparative test between drivers anywhere, apart these resolution test by Ink stained Fingers (thanks !!) here on the forum. So I have no idea what the difference would make on print quality in real life. Any references on that ?
New color support in gutenprint:​
A side questions, probably naive, for printer driver specialists. I don't quite get why, in gutenprint for example, it seems so complicated to add a new ink (apart from finding how to speak to the printer).
It seems to me that it would be the role of a spectrophotometer to solve these kind of problem...?
Isn't any "automated"/direct way, to find parameter for the printer to avoid days of tweaking, and 100 sheet of paper ?
What is the actual relative importance of parameter tweaking/icc profile calibration in the quality of color reproduction?
I'm guessing that calibration with spectro is when printer already behaves quite close to the "optimal" color reproduction. Calibration software, like argyll, are working in rgb for the P900, which is quite high level compared to printer inks. And that the dithering methods and parameters about how and how much the driver lay the inks is much more important. Do someone has more knowledge/references on that?
What to do in practice?​
Considering the current gutenprint support of the P900, the use of airprint it advised by a gutenprint developer. Has anyone experienced printing through airprint on linux with the P900 ?
In general, what would be your advice to get my printer working, considering my needs ?
Anyway, thanks for those fo you that went through this super long post, a big thanks to the whole community here, to share so much tests and information about printing. It is really refreshing !
When using Linux and have full control, you want to be using Gutenprint. Either with their print dialog or using the more advanced Gimp plugin.
Turboprint is the easy way of doing things if you don't mind paying for their software and profiling service. You cannot load your own profiles into their closed software. I still use the free version of their software to quickly print a nozzle check though.
Gutenprint is essentialy a very basic RIP that lets you control any available parameter of the printer, and the Gimp plugin offers even more control like adjusting linearization curves. To use your profiles you can either apply them to the file with ArgyllCMS (there are some GUI builds) and print with GP dialog color correction "uncorrected", or apply your profile in Gimp and print there with the GP plugin. Find a lot of the parameters explained in the user manual.
But as with everything open-source, you will have to wait until someone writes some code or do it yourself, the issue you are facing right now. This will most likely eventually happen but considering it's an expensive printer using 10 carts, with a different model printhead and a new color, it's not so much copy paste as you might think. Eventually the right person will get their hands on the device for near to nothing and put in the work.
For a temporary workaround solution to print with Linux you might want to try using virtualization like Virtualbox and print using the Windows driver.
Epson claims that they provide Linux drivers for their printers. Search for Linux on their printer home page. They do not support those drivers, but if the drivers work, support shouldn't be necessary. I have seen some opinions that they work well. I have also seen claims that the driver was just built in to their distro. Did you try and find that your printer isn't supported?
EDIT: Your printer appears to be one that isn't listed! There is one for the P9000. Same??? I do notice that they even have one for the super-cheap ET-2850.
Hello,
I don’t know what your status is now? Already a long time after your post.
I’m in the same boat. Epson P900 and migrating from a Mac workflow to Linux. So from an almost perfect print environment to cowboy print land. 😊
I’m ended to buy TurboPrint and because the need and will to print roll and A2 Yes the Biggest price.
I’m now very busy with making the needed profiles.
The result was strange. Almost every time the prints were ok-isch but not spot on. A bit too dark and over saturated.
And I could not put my finger on. Until today and got an idea. It was always that the calibrated screen was ok and fresh. And the reds are over the top. And in tp I send just as I did in macOS and windows11 choose for AdobeRGB. As color profile. When I choose for sRGB then the saturation was less and almost good. So I think that the canned profiles from Epson and the paper guys. Are profiled on sRGB. Then you don’t have the saturation problem due the lesser gamut. And the guys with a adobe screen will probably build their own profile’s because the are not satisfied on the poor profile gamut.
But my monitor is a P3 display and yes in the red is P3 far behind AdobeRGB. Thus I imported the official P3 icc profile. And let turboprint render the output in P3 and the profile (the 875… from farmacist.) And yes it dit the job.
Thus long story short.
I have my first good working printer profile with a bigger gamut than I had in my Mac time.
@pharmacist. Thanks for your good and deep post about profiling with Argyll and the i1 pro2
Hi Ron,
thanks for your kind words. Your name sounds rather dutch/flemish: je bent ook Nederlandstalig ?
Hi Ron,
Ja Nederlands. Hoewel de naam Cromberge volgens de historie van de naam het ergens uit België stamt. Maar toen waren we nog de lage landen in de 80 jarige oorlog 🤪
I didn't feel like waiting for a Linux driver anymore, or using Windows. So I built my own driver. (Yes, using AI.)
The print quality matches that of Windows exactly.
Epson SureColor SC-P900 CUPS Printer Driver for High Quality Output
https://github.com/colorcube/epson-p900-escpr-cups
Printing isn’t exactly trivial, though, and you only get the best print quality if you control the printer correctly. I’ve always liked Epson Print Layout.
So I also built a corresponding printing program:
LumaPrint
https://github.com/colorcube/lumaprint
The prints that LumaPrint produces are not 100% identical to Windows prints because color management differs (LittleCMS vs. Windows ICM). Practically, I can't see any difference, and comparing the raster data shows that the differences are minimal.
And as an alternative to the Epson Media Installer (for custom papers / .emx files):
EP Media Installer (epmi)
https://github.com/colorcube/ep-media-installer
Note: These are early versions, but they work well for me. (.deb and .rpm packages are available in the releases.)
Hope you like it
PS:
Display calibration for KDE Plasma on Wayland
https://github.com/colorcube/kelvincal
Halll rfritzzz,
Well done – excellent work and a great foundation.
The framework is certainly good, but CUPS is becoming obsolete and is being replaced by https://github.com/OpenPrinting/printer-application-framework. Incidentally, there is a port of GutenPrint for this standard. It would be really great and forward-thinking if you were to port your project to this standard in the future. https://github.com/OpenPrinting/gutenprint-printer-app
Microsoft is also currently working in this direction and developing PSA.
I’m a Linux user too, but I print from Windows. I’ve also decided to make my own RIP open-source, but for Windows. After all, most people use Windows. Although the backend was deliberately written in Python so that it could be easily ported to other systems. Even so, every operating system has its own GUI and its own printing system, so it’ll have to be developed for each OS anyway. Well done – you’ve created an excellent foundation.
I’ve already developed enough for my own needs and my own printers, and everything works perfectly. If there’s still interest from the community, it could be ported to Linux as well.
I’ve had a look at your code; basically, it’s all clear – what’s what and where it comes from :-). I can throw in a couple more ideas for things you might want to add to your driver... Oh, there’s still plenty that could be improved and added. Epson is pulling the wool over all our eyes and limiting us by labelling its printers as RGB. Whereas, if you know how to control each channel, you have complete freedom and can implement any colour model; the only limits are your imagination and the number of coloured inks.
:thumbsup
I’ve read your article; I suppose it was written by an AI, or perhaps it misled you. Point 3, in particular, should be the first item on the list and the most important one.
I don’t see this as an advantage, but rather as a very serious and terrible drawback.
https://github.com/colorcube/epson-p900-escpr-cups/blob/main/docs/why-not-gutenprint.md
I consider the implementation of the ESC/P-R protocol not an advantage but an absolute and appalling evil that only Epson could have perpetrated.
We’re limited solely by the RGB firmware and won’t be able to change anything else. If Epson goes on to implement this in other printers in future and disables ESCP2, that’s it – we’re done for. You can forget about RIPs, any colour models, or custom ink sets. They’ll cut you off at the knees and turn us into wooden puppets. Naturally, Epson doesn’t want you to turn a 6-colour printer into, say, a CMYKOG; to do that, you’ll have to buy a printer that’s ten times more expensive.
I would summarise my main concerns as follows:
  • RGB-only firmware - severely limits the ability to use alternative colour models and custom ink configurations.
  • A proprietary protocol - potentially prevents independent RIP developers from directly controlling individual print channels.
  • The abandonment of ESCP2 - could destroy compatibility with existing RIPs, alternative drivers, and custom printing configurations.
  • ESC/PR as a mandatory standard - creates dependency on Epson's implementation and decisions, rather than allowing users to exploit the actual capabilities of the printing mechanism itself
I fundamentally disagree with presenting ESC/PR as an advantage. From the perspective of independent RIP developers and users who value control over their hardware, this is a serious restriction of freedom, not a technological improvement.
Best Regards,
Alexander
Back
