dan_uk_1984
I haven't used the my i9950 for a couple of weeks and although I use refilled cartridges in my MP760 I've only ever stuck to OEM's in this. I really wasn't expecting a problem but if you check out the bottom row of nozzles on the BCi-6BK nozzle check you can see that I have an odd nozzle.
Trouble is I don't think it's blocked, I think it's actually damaged because the line is the right length to fill the hole, it's just not aligned properly. This results in a double layer of black ink being put down because the line lines up with another further down etc.
I've done a few head cleans, flushed the black through with window cleaner to no avail. I've left the head in solution to soak over night in the hopes that there is a partial blockage that is just changing the angle of the spray.
Has anyone else had this and resolved it without replacing the head?
Thanks in advance,
Dan
Thanks in advance,
Dan
