I've just got an Oce CS2044 (42" Plotter) ... Well actually it's a Canon imagePROGRAF W8400 with an Oc badge stuck on
. I've found that without using any color matching the print comes out way to blue, while using their ICC profiles it comes out way to yellow / green. I don't mean slightly - the gray-green headres on this page will come out looking nearly neon.
So into the Color Matching Workflow I'm going ... augh
This is a pain in the neck - shouldn't the matching methods work the other way round?
The way all matching programs work is to match your scanner / camera to a preset colour chart (e.g. Pantone), then match your screen to that same chart. Then print about 200 to 1000 :O prints adjusting slightly on each colour on the chart - this may take a month or more
Most of these programs (actually all) simply save a table of correct colours referring to printer "error" colours, then the ICC (or ICM) colour matching interpolates the colours not found in the table so you don't have to save 16 million colours to cover the entire RGB spectrum.
Instead of following the hit-and-miss approach for printer mathcing above, could you not do something like the following?
After matching your scanner / camera and screen - which isn't half as difficult as matching the printer. Could you not print out a test chart of various colours (something like a Pantone chart)? Then choose the closest match (on screen - varying the Hue, Saturatiuon & Luminance to suit) to each of these printed colours - in essence telling the matching program the colour "errors" the printer makes. Then the program could simply referse these - you may have to print a few times just to fine tune :| but you could come very close in one step instead of hundreds
Of course the more colours in your chart the more acurate your final icc profile will be.
Does anyone know of a system which could work this way?
