color very dim on my Canon MP240
You're right, it does appear that something in the settings has changed.
What happens if you print without the hookup to your Mac? For example, if you copy a photo? Or if you connect a camera directly to the printer?
If it's only when connected to the Mac, then I don't know if the Mac version of drivers is significantly different than the Windows version that might account for the problem but I would suggest that you find a friend with a PC, maybe a laptop, that will let you install the drivers on it to see if that makes a difference. Or you could just uninstall the drivers on your Mac and reinstall them. I'm assuming that the uninstall/install works on a Mac like it does on a PC.
jaybee3x3
After more experimenting (and using about a third of my new ink cartridge) here is what I have found: If I print on plain paper, 8.5 x 11, with plain-paper settings, I get correct color. If I print on either photo or regular paper, 4 x 6, I get the weak, pastel color. The same is true, whether the picture is printed from within iPhoto or not. (I even tried downloading a photo directly from the camera, not using iPhoto in any way and got the pale color when I printed the 4 x 6 size.)
The problem seems to be connected to the 4 x 6 size; iPhoto is not the problem. In every case I am using the regular "photo" preset in the print dialog box. I am at a complete loss to understand this???
When you say "regular" paper, do you mean "plain" paper?
Are you saying that whenever you print to 4 x 6 you get the pastel color but any other size, no matter what the paper is OK?
What happens if you print to 6 x 4?
What happens if you copy a 4 x 6 image to 4 x 6?
Your photo preset is not set to fast or draft quality, is it? On the Windows dialog box there is a Default button on the Main tab, have you tried hitting that button?
jaybee3x3
Yes, when I say "regular" paper, I mean "plain" paper.
Yes, when I print 4 x 6 I get dim colors. Other sizes are ok.
I don't have a preset for 6 x 4, but when I asked for that size (custom) I got dim color and it was printed in the same orientation as normal 4 x 6.
I saved a copy of a photo as 4 x 6, then pasted it into a word processor and printed it. I got good color, but there was no option in the word processor print dialog for 4 x 6, so although the image was 4 x 6, the printer just considered it a portion of a letter size page.
I am on a Mac. The only default button I know about is in my "System Preferences" where I can set which of my two printers is the default printer. (My B & W printer is set as the default, so each time i print color, I have to select the Canon on the drop-down tab.
When you go to Properties or Preferences or something like that after you tell you application you want to print but before it starts printing, don't you see a dialog box with half a dozen or more tabs in it? And isn't one of them labeled Main?
jaybee3x3
Okay, apparently I have solved at least a part of my problem. I have been printing borderless 4 x 6's and getting the dim color. After reading some of The Hat's explanations in his link, I tried printing with borders. Voila! Bright color! Just to be sure I went back to the borderless setting and got the old dim color. So apparently the borderless setting is the problem.
What I don't understand is, why, before replacing the cartridge, I got good bright color using the borderless setting. The only possibility I can see is that the old cartridge was C211 and the new is C211xl. I thought the xl just meant larger capacity, but maybe I was wrong. Although at one point I re-installed the old cartridge and still got the dim colors. ???
Anyway, I guess I'm okay for now. Many thanks for your help. I guess if I want borderless prints, I'll have to get out my old paper cutter.
officeinks
jaybee3x3 said:
My printer was printing photos beautifully, then suddenly I got wide streaks. I replaced the cartridge (CL211xl) and when I printed everything came out a pale pastel. Thinking the cartridge might be defective, I got another cartridge. Same result. I even reinstalled the old cartridge. Same result. The nozzle check shows no clogged nozzles. I assume something has happened in the settings, but I have have no clue. The online manual recommends setting it to "vivid color." I did that; no change.
Any suggestions? (I'm on a Mac, if that matters.)
Once you should buy Compatible Cartridge from genuine shop. Before purchasing of cartridge you need to check series of your printer and the cartridge you supposed to purchase.
