- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
I wonder if this behaviour is related to the problem mentioned by Tudor in posts #53 and #55? The larger ink chamber might make the printer "assume" there is an ink flow problem, as the ink chamber still contains ink when it ought to be empty. Maybe this causes problems for ink monitoring?
Maybe the CLI-8 cartridge has a reduced sponge capacity due to many refills? Purging the cartridge should then solve the problem.
Is it possible to fit a CLI-521 or CLI-526 in the modified printer and see how it behaves with the original cartridge?
It seems a good idea to change the cartridge when you get the low ink warning, as this seem to still work.
