pixmania
- Dec 23, 2012
Just made an interesting discovery, if you use a sharp blade and cut across the label just under where it says the colour of the cartridge. You can then peel off that part of the label and rub of the adhesive residue to reveal the transparent top of the cart. Then you can see the ink level as you fill quite easily. No need to swap for 521 carts etc. I also drill a small hole in the plastic ball that plugs the original filling hole, then screw in a very small self tapper aero modeler size then just pull the ball out using pliers on the screw, easy.
