Cleaning print head with aquarium tubing and syringe
kevindd992002
For a Pigment Black-clogged Canon Pixma MP830 print head, what size of aquarium tubing is appropriate in "sucking up" Windex solution from the bottom of the head to the ink inlet port? I read that 3/16 OD is used for the color inlet ports.
cls
Germany Hamburg
i dont know bot canon printheads and ammonia doesnt sounds good to me...
kevindd992002
Not to most people in this forum. But anyways, my questions is about the OD size.
ThrillaMozilla
You need to know the ID. Use whatever you can to measure it. A ruler will give you a pretty good guess.
barfl2
Hampshire U.K.
Yes 3/16" about right for the C/Y/M/B PB is larger I use a needle scabbard with the plain end cut off. its 2" long and being rigid stays upright. I use it with a standard syringe, works well for me
