gfreed
- Feb 25, 2008
I have a old HP 2410 and I refilled the color cartridge and got it working perfectly. After a day or two the color will not print correctly. Tests indicate that some of the ink jets are not working. I then talk the cartridge out and pressurize the tanks having the problems expelling a drop or two of ink from the malfunctioning jet arrays. I then clean the ink jet head off and reinstall the cartridge and do an alignment and it works great for another couple of days. When the cartridge parks is there something that is supposed to seal the heads? I looked with a big bright flash light and found that when you turn the printer off with the carts removed a tray slides forward with what look head seals used when the heads are parked. I cleaned then with cotton swaps and water. I also found that if you leave the printer on all the time it takes a long time for the heads to PARK and seal so I turned the printer off after using it. Anyone got some more ideas? I would sure like to get some new rubber head sealers. I would also like to give that printer and good cleaning but I would have to disassemble the printer to do that and I need a manual.
