- May 29, 2007
- Location
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
I'm wondering how long it will take to get your printer generating the "waste ink pad full" ? I know you can reset the message, but how many times is it save to ignore the message before your printer really floods over ? And is it possible to -like the epson printers- guide the ink away from the printer with tubing of some kind ? It's a pity that those printer companies didn't make a design with a special inktank that can be taken away from the printer (in a special cartridge or so and behind a lid). Has anybody tried to build such system to guide away the waste ink from the Canon printer ?
Maybe I should take a specially made vacuum cleaner and suck the ink away from the ink pads, will this also create a vacuum causing the ink to flow upwards toward the ink pads (from the underlying felt pad and through the tubes) and then sucked away from the printer ? And then do a reset of the "waste ink pad full" message ?
Is this a feasible alternative instead of completely dismantling the printer and replacing another ink waste pad underneath the printer ?
