- Nov 27, 2010
- Location
- Copenhagen Denmark
- Canon MP990
I have a Canon TS6150 that I have kept as a spare printer. When I wanted to do a nozzle check for maintenance/keep alive the printer wouldn't turn on. It lit the power light but didn't start.
So I decided to remove the printhead to see if that prevented the start up. It didn't, the printer was still dead without the printhead. But here is how to unlock the printhead. Many Canon TS models are similar, so the instruction should also apply to those models. Click to enlarge the images.
Step one, remove two screws from the back:
And this from the top after opening the lid:
Now release two latches at the bottom using a flat blade screwdriver:
The side panel can now be removed so you get access to the printhead lock, push down the printhead locking tab:
I kept the cartridges and am going to dump the printer, but first I will continue to take it apart to locate and remove the paper out door indicator switch. I will need the switch for a TS5055 that often pauses during print due to a problem with that switch.
Even if my repair attempt was unsuccessful I hope this instruction will be useful for owners of similar printers.
