marco565
- Jan 4, 2022
- Munich, Germany
- Canon pro 10, Epson ET8550
Hi All,
Since I recently revived my very cheaply acquired canon pro 10, I will like to start a comparison of the 2 printers. In this thread, I will only talk about VISUAL image quality. I will not talk about Inks (pigment vs dye) nor any printer specifications.
Just to put things clear, I am running both printers on OEM ink. Profiles that I will make myself are created using a spyder print with the 255 patches (I haven't seen much difference with the 729 patches option on the ET8550).
PS: method of scanning patches with spyderprint is patch by patch press button (otherwise profiles are wrong!).
First comparison on canon premium matte paper (PM-101):
- ICC: the wired space is the one from the ET8550, the colored one from the Canon pro 10, both profiles are made with spyder print. The gamut of the ET8550 is clearly much bigger
- Image comparison (full size) was shot using an a7rIII 20f1.8 @f4 calibrated using the xrite color chart, using daylight (not bulb light). First on the left is canon pro 10 with driver profile, then Canon pro 10 customer profile on top and bottom ET8550. use the full size image to see more details.
My personal observation:
- The 8550 looks more saturated and darker darks.
- Strawberries look much more eatable on the 8550.
- Lava looks more accurate on the pro 10 and we can see much finer details.
- Autumn forest is more saturated on the 8550 and looks better.
- Colored stones (top middle image) look too saturated on the 8550 sky gradation look good on both.
- sunset beach does not look good on the Pro 10, probably a profile issue since with driver color it looks more natural.
- B&W look more neutral on the pro 10 (obviously)
- Gradation look good on both images.
- Color patches look better on the pro 10, they seem to be a bit closer to what I get on my calibrated screen.
Conclusion:
Personally, I prefer the colored images on the ET8550, however, the pro 10 looks more natural. The Pro10 has more sharpness (that might be because of the software resizing the images, I used Epson Print layout and Canon Professional Studio).
Tell me what do you think about this test, does it makes sense? If so I will continue when I will have time on those papers:
- Canon Glossy plus II
- Canon pro luster
- Fotospeed NST Bright White
- Fotospeed Platinium Etching (when I will receive it)
- Hahnemuele photo rag 188 (same as the 308 but thinner)
Conclusion:
- Canon pro luster
