gwrentch03
- Dec 20, 2005
Hi.. I have searched everywhere and cannot find a answer to this issue I have been having with my old printer. I have done cleanings, deep cleanings multiple of times and when I do a nozzle check everything checks but the photo magnetta. I contacted canon and they said to power off the printer, take all the cartriges out and remove the print head for about 30 seconds and then put it all back and run the check. I did and the PM worked for about one check and then stopped again. I thought I had a bad print head so I purchased another one and went through the same thing and again every color printed but the PM. My pictures were very blue and green since the PM wasn't working. So I thought maybe my old printer was bad so I purchased another printer and received it yesterday, I put the new print head in with my non OEM replacement ink and tried it on the new printer, the nozzle check resulted in the same thing, but with the new printer there was a hint of PM. I tried replacing the PM ink with another and had the same issue so I just took it out and put the original canon ink in and ran my nozzle check and it worked. All colors printed fine, took a test picture and it was awsome with the new printer... Anyway if someone has had this issue please let me know what you did to fix it. At this point the only thing I can think of is to use OEM canon PM and the rest I can get away with non OEM brands on my new printer. One more monkey in the wrentch with my old printer is if I take out all the cartridges and do a printer status it shows that according to the ink levels I still have my cartridges in when I don't.. kinda weird.. wonder if the printer is just bad or the sensors are bad. Anyway please let me know if you have any idea what I should do.. Also I did uninstall and re-install the drivers... Thanks.. Vince
