- Jun 16, 2006
- La Verne, California
- Epson WP-4530
I was asking about if you get a new printer like the MP560. Are there cheap third party cartridges available for it?
Continuing to run a printer after the ink tanks are empty will not cause the problem you are having. I suspect that during the course of removing the print head and dismantling the printer, you caused an electrical problem such as a short or broken connection. I have mentioned before, you really can't know if the problem is just in the print head or just in the printer or both, until you get another working iP3000 and swap parts. But then you run the risk of propagating failures from one bad unit to the next and it just isn't worth pursuing. If you really wanted to stick with the iP3000 and you got another one, it would make sense to just abandon your broken printer with its print head and start using the replacement. It would not be wise to experiment by swapping parts or you will likely end up with two dead printers. It's time to "retire" your defective iP3000.inca said:Yes, when the print head is inserted, it wont turn on. If removed, it will turn on.
I had been using it past when some of the tanks were showing as empty. Perhaps this burnt something out on the print head or clogged something on the print head. Visually, the print head looks fine. What can I do to attempt to fix/repair the print head? New ones on Ebay are $57 delivered. If they cost that much, I'd rather buy a totally new printer for $78 at WMT for the Canon Pixma MP560 or the Brother MFC295CN for $60-70 at Staples or OfficeMax.
When the print head is "bad" is it because the ink is dried or because something is short-circuited or broken in the electrical connections?
