- Jan 18, 2010
- Residing in Wicklow Ireland
I think you should go back to the very start again because you have introduced too many variables
and you now can’t isolate your original problem properly.
Pop in a brand new set of OEM cartridges and don’t run any cleaning cycles first,
then just run a standard nozzle check then print off one sheet with four
2.5 cm x 10 cm colour swatches and see how they turn out. (Use this one)
If you’re test print-out is not 100% then your only alternative at this stage is to get a new print head and hopefully you haven’t damaged your logic board with all of the testing and cleaning on your damaged print head..
