Hello
Im new to the forums. Found this site while searching for answers on how to fix an error that my printer is giving me.
I have a Canon MX330 which i bought brand new about a year ago. I turned it on today and the error alarm went off and told me " Error U015 - The following Ink Cartridges Can Not Be Recoginized" and it highlights both the color and black inks. So i shut it off and turned it back on and now it tells me the same message but only highlights the blank ink. Sometimes it says both and sometimes just the black, it cant make up its mind lol.
I know the cartridges are correct because they came with the printer. I refill my own ink with high quality inks and i use the factory fill holes on the cartridges using a very small insulin medical needle, it fits the very tiny hole perfectly so you dont have to make the holes larger. So by doing it this way it also keeps the cartridges from leaking. I put tape over the holes and leave the very tip of the air flow canal uncovered just like the factory sticker does so the ink flows the way it should as well..
These cartridges have worked fine all this time and now im getting this error. I dont want to go buy new ink and still have it tell me they are wrong. These inks are too expencive. Does anyone know how to reset this error or correct it ? I need this printer to be working because my small business relies on this for printing out lables and boxes.
So please if anyone knows how to fix this problem i would be greatfull
Thanks in advance
-Curt
Thanks in advance
-Curt
