- Jun 16, 2006
- Location
- La Verne, California
- Epson WP-4530
This information has been posted elsewhere but it was unnecessarily confusing so I'm making my own set of easy-to-follow instructions:
1) Press the following keys in sequence: Copy-Menu-Scan-Copy-Scan.
The display will say:
SERVICE MODE
#1 SSSW
2) Press the V key six times.
SERVICE MODE
#7 PRINTER
3) Press OK.
#7 PRINTER
#1 SSSW
4) Press the V key four times.
#7 PRINTER
#5 INK ABS CAPA
5) Press OK.
SUCTION
XX (where XX is how full the waste ink tank is as an integer percentage)
6) Change the XX to 0 by hitting the < or > keys as many times as necessary (if you are closer to 99 than 0 it is better to hit the > key until it wraps around to 0).
SUCTION
7) Press OK.
The display will momentarily say:
SUCTION
DATA ENTRY OK
and then will quickly change to:
#7 PRINTER
#6 CDR ADJUST
8) Press the Stop/Reset button
And the printer is back to normal.
SERVICE MODE
#1 SSSW
SERVICE MODE
#7 PRINTER
3) Press OK.
#7 PRINTER
#1 SSSW
#7 PRINTER
#5 INK ABS CAPA
5) Press OK.
SUCTION
SUCTION
7) Press OK.
SUCTION
DATA ENTRY OK
#7 PRINTER
#6 CDR ADJUST
