Canon Mg6220, Did I Break It?
icarr757
This is very frustrating. I have a mg6220 that has been printing great until recently. I have used the german method of refilling since I had a ip3000. Recently I have noticed when refilling my yellow and magneta carts I get alot of bubbles building up in the res tanks, and I have to syphon some air from the sponges when filling to prevent ink overflowing from the top vent, the hole I am filling from, or even from the main port. Now, my yellow has become very streaky. Run a clean cycle, nothing. Run a deep clean, it clears up. I print off 5-10 pages, yellow goes back to streaking. I have done enough deep cleaning cycles that I have almost drained all my other color carts twice. Yellow works for a few pages, then starts streaking again. I have even bought new yellow carts from local Staples. Same.
Highly frustrated. I print check pattern, it looks perfect every time. Print page, yellow streaks... Any idea why it would continue to gum up every few pages? Clean up for a few pages then go right back to shit?
Thanks!
Note, I only refill original canon cartridges that I have bought from local Staples (I swap chips that came w/ the printer original cartridges to 220/221 bought from Staples) and I have been using ink from Hobbicolors. And a chip reseter.
For drying the cartridges after flushing, I use and recommend ghwellsjr's paper towel method: http://www.printerknowledge.com/threads/draining-a-canon-cartridge.4760/
It is my experience that the newer and smaller windowed and opaque cartridges need more frequent flushing than the older and larger transparent cartridges. I think flushing for around each 5 refills will be needed.
If you have a small digital scale with a capacity of 100g or 500g and with a resolution of 0.1g or 0.01 g you can use it for a health check of your cartridges/ quality control of your refill.
The weight of new and unused PGI-220/CLI-221 cartridges without the orange clip and vent sealing tape is 35.3g for PGi-220 and 20.3g for the CLI-221. The weights are the same for the opaque PGI-225/CLI-226 cartridges.
A properly refilled cartridge in good condition should have a weight close to these weights. If the cartridges are more than 2g underweight for the pigment black cartridge and more than 1g underweigt for the dye cartridges, then I recommend flushing and drying the cartridges before they develop ink flow problems.
icarr757
Thank you, I will certainly give it a try tomorrow. Still, since this problem started, I have gotten a new yellow cartridge from Staples. But I am willing to try anything right about now. =P
New cartridge should hopefully resolve the streaking. Flushing the old one and reusing could save $$$ in the future. We like saving money. :D
