- Nov 27, 2010
- Copenhagen Denmark
- Canon MP990
I have an MG5550 which is the European version of the MG55540. I use these single use compatible cartridges from a Danish supplier. They work well and the colour match is good. There is one drawback though, the "big black" cartridge is filled with dye ink instead of pigment ink, meaning that text is not waterproof or highlighter resistant. A set of 5 cartridges is DKK 65 or approximately £ 6.50.
Some compatible or refillable cartridges work well, others don't so watch the print quality carefully and stop printing at the first signs of ink starvation or clogged nozzles, to avoid damaging the print head.
Compatible cartridges for single use should not be refilled, even if they have worked well. You risk ink starvation, see this.
I suggest to try the refillable cartridges mentioned by stratman or if you can find some reasonably priced compatible cartridges for single use for the MG55540 then try those.
I go out and buy yet another Friggin Canon printer...
