If you mean by "chipset" the individual chip on the cartridges then yes. You will need to swap the chip on the cartridges you currently use to new cartridges you buy after your move to a different region than your printer is sold in. In other words, the cartridge chip must be of the same region as the printer's internal programming/EEPROM/chipset is.
The easiest way around this is to use a chip resetter if there is one for your cartridges. Have two sets of cartridges and reset and refill them. Be aware that a cartridge's chip can fail without warning or apparent reason. Your ability to source new chips for your cartridges, or the whole cartridge with chip on it, may be costly if you move to a new continent.
An alternative to a chip resetter is to buy ARC chip, either attached to aftermarket refillable cartridges or as single unit you attach to your own cartridges. Alibaba Express may be a good source if you cannot find in your own country.
FYI - if possible, it is recommended you use OEM Canon cartridges for refilling regardless of what chip is on them.
