Canon Imageprograf TC 21 /Lucia TD inks and harvesting inks from 300ml/ 700 ml cartridges
hdtvjeff
I really do not know and don't trust AI completely
The brand new Canon ImagePrograf TC 21 is a CMYK 24 inch plotter. I would love to now if it's possible that these inks are LUCIA TD inks. The TC 21 uses PFI 050 70 ML bottles to pour into tanks, NO carts. They are expensive at $70 each for each of the FOUR 70 ml bottles. There are TM and TZ series 5 color printers that are LUCIA TD specific in cartridges up to 700 ml in size. Love to siphon those OEM carts.
Canon didn't say yes or no but I get the feeling its possible.
Canon in 2023 also updated Magenta in their TM/TZ lines in one case going from a PFI-30M to a PFI-31M as magenta seems to be improved recently.
Is it possible the TC 21 printer does use LUCIA TD inks though not stated and siphoning ink from TM/TZ plotter printer series big carts would work?
So basically asking if TC 21 inks are the same as the latest TM/ TZ ink sets but just not stated as such since Canon would lose profits from people not buying their bottles for the TC 21
Thanks in advance and much appreciated for any advice, first hand experience or help
I don't see a reason why Canon would hide Lucia inks and not telling you the benifits of that ink: I tather would assume that the TC-21 inks PFI-050 are closer in properties to the GI-56 135ml bottled inks of the GX series office oriented printers. But it's up to you to use other inks in a TC-21, you just need to run some tests - e.g. gamuts of profiles , gloss performance etc on your papers.
Pricing - Canon offers a rather low unit price and high ink prices, Epson does the opposite with the TC-3100(X) - a higher unit price and lower ink prices
hdtvjeff
Thank you, it seems the GX series uses a hybrid of Pigment and Dye based not all pigment like the TC 20/21 models
hdtvjeff
You have quite a range of inks you can use, but you would need to run some tests - profiles to verify all your assumptions.
hdtvjeff
Indeed. Just wish i knew for sure if the Canaon Imageprograg TC 21 used Lucia TD inks as AI says but Canon won't verify
CMYK should be easier to match than 12 color pro ink sets
Thank you !
hdtvjeff
all colors of the GI-56 inks for the GX.... series printers are pigment inks
https://www.druckerchannel.de/devic...axify_gx6550#verbrauchsmaterialien_reichweite
YOU ARE RIGHT, 100 percent Right. the GI-26 is IDENTICAL to PFI 050. Same ink. 132ML bottles, half the cost of pfi 050 70 mml bottles
EDIT: Another web source says similar NOT identical
FROM AI:
Yes, you can siphon Canon GI-26 ink and use it to refill a Canon PFI-050 bottle because both are pigment-based inks and compatible in terms of chemistry. In fact, many third-party vendors market the same refill ink for both series.
Key Compatibility Points
  • Ink Type: Both the GI-26 and PFI-050 inks are genuine Canon pigment-based inks, which are designed for durability, water resistance, and crisp text.
  • Chemistry: The underlying ink chemistry is compatible, which prevents adverse reactions that could clog the printhead or damage the printer (a risk when mixing different ink types like dye and pigment inks).
  • Printer Compatibility: The printers that use these inks (MAXIFY GX series for GI-26 and imagePROGRAF TC-20/TC-20M for PFI-050) are both designed for thermal pigment 4-color inkjet systems.
  • Refilling: The original bottles are designed with a specialized "keyed" nozzle shape to fit the correct ink tank easily and without a mess. Siphoning and transferring the ink into an empty PFI-050 bottle, which retains its correct "key," is a viable method for refilling the intended printer.
Considerations
  • Siphoning: You will need a clean syringe or a similar tool to safely transfer the ink without spills or introducing contaminants.
  • Volume Differences: The GI-26 bottles (e.g., 132ml color, 167ml black) typically have a larger volume than the PFI-050 bottles (70ml). This means you may have leftover ink, which should be stored properly.
  • Warranty: While the inks are chemically compatible, using ink transferred from a different series bottle (even genuine Canon ink) is a modification not officially supported by Canon, and any damage caused by the refilling process itself might not be covered under warranty.
In summary, the inks are interchangeable in terms of composition and function, making your proposed plan feasible for refilling your PFI-050 system.
Thank you !!
