canon fax b160 how to refill cartridge bx-20?
passenger
Croatia, Europe
no one?
bx-20 is all in one ink cart + printhead used for faxmachine. which black ink to use? pigment or dye?
billkunert
Georgetown, Ky
HP Envy 5530e
If you run water across a print and the ink runs, chances are it's dye ink. Pigmented ink is normally more water proof. As far as how to refill-can't be any help
jasiiboss
Dharamsala, India
This is a high capacity cart. Uses Pigment Ink and is mostly found in canon AIO viz.canon 7...series
To Refill there are vent plugs. If you look at the cart with the label facing you they are on the right side.
Remove these Fill about 30ml of ink and reseal and you should be done,
Cheers;)
Rgds,
passenger
Croatia, Europe
billkunert, good tip - water on print seems like it is dye,
jassiboss said pigment.. so i'm not sure :/
from this specifications anyone knows is it dye or pigment?
vent on top, this is for refill?
vent on bottom used for?
