WISVET5951
- Nov 22, 2012
The question is can I use the MIS ink that I used to fill the cli 8 cartridges in the cli 226 successfully?
I have a MP 810 which after 4 years of refilling finally plugged up the pigment side of the print-head. In the past a flush with warm water and followup with alcohol corrected the problem. I replaced the head and it promptly plugged. The head is now soaking hoping to soften the clog. My backup, which was in storage for those 4 years is a IP4200 and it too has a blocked pigment channel. I probably made the mistake of refilling the same PG cartridge many times.
If I can not get them to work, I will replace them with a new Canon multifunction that will no doubt have the cli 226 cartridges. From browsing here it seems that the 220 & 226 are the same. I have from 2 to 4 oz each of the dye base and 6 oz of the pigment ink. I may just discard the pigment ink, because of the problems with the heads and buy fresh.
