- May 29, 2007
- Location
- Ghent, Belgium
- SC-900 ET-8550 WF-7840 TS705
After my recently purchased i1 Pro 2 device, I made this 648 patch target to be printed on a single sheet of A4 (210x297 mm). Optimized to be used with the dedicated ruler/jigg of the I1 Pro 2 device. The modified target has a clear black marker line with a white area on the paper surface to start the spectrophotometer from and ends with a same white area to end the reading (start scanning from the left white area to the other white area). The target has an entry form to fill in date, type of paper, ink used, PK/MK, GO: yes/no, paper/media setting/resolution setting used to print this target, type of printer, profile name. This enables you to document this whole process.
It is based on 8^3=512 steps in each XYZ axis of the color space + 128 grey steps (with emphasis around the neutral axis to optimize neutral BW-printing) and 4 white and 4 black patches making in total 648 patches.
