Nov 18, 2010 #1 D dwolf Getting Fingers Dirty Joined Oct 21, 2006 Messages 44 Reaction score 1 Points 26 I have always drilled a hole at the top of the cart and filled from there.. I see some instructions show you to remove the ball and do it from there... what is the difference ??
Nov 18, 2010 #2 The Hat Printer VIP Platinum Printer Member Joined Jan 18, 2010 Messages 15,915 Reaction score 8,923 Points 453 Location Residing in Wicklow Ireland Printer Model Canon/3D, CR-10, CR-10S, KP-3 dwolf The Canon refill hole saves you from having to drill a new one and you can get special bungs to fit the hole perfectly. Then there is the German method of refilling, you should check it out here.. http://www.nifty-stuff.com/the-german-durchstich-refill-method.php
Nov 18, 2010 #3 G ghwellsjr Printer Master Platinum Printer Member Joined Jun 16, 2006 Messages 3,645 Reaction score 85 Points 233 Location La Verne, California Printer Model Epson WP-4530 Yes, the German method doesn't require an absolutely air-tight plug.
