Ammonia and alcohol + heat dangerous?
Smile
Europe EU
Hmm did anyone notice that ammonia when heated (coffee hot) gets very aggressive and is a very high risk factor? If you mix it with alcohol you can even unglue print head assembly and damage the head.
It happened a while back with HP500PS plotter print head, luckily you can replace the heads one by one as it uses single color heads.
Also ammonia fumes corrodes brass. Put a coin in it - nothing happens, remove it to get air contact watch it turn green :rolleyes:
This is with 10% ammonia and distilled water container. I wonder what concentration it's in windows cleaner? Since I can't buy them locally.
Perhaps HP print heads are different?
mrjenkins
Ah, that sounds very dangerous. I would suggest a different approach to cleaning. such as flushing with cleaning solution
Smile: for a cleaning solution for clogged nozzles a few drops of concentrated ammonia (30 %) should be enough for 100 ml. To much and you will corrode your sensitive parts inside the printhead.
Froggy
Midlands, UK
What are your sensitive parts doing inside a printhead? :|
Froggy,
A Freudian sllip of the pen: the delicate parts inside the printhead. ;)
