5100 Service Error with Refilled Cartridges
deniz
Hi, I've a Canon Pixma MP620. I used it till yesterday without any problems. I bought a Precision Colors refill set and filled my original CLI-521 cartridges with it. After refill, I resetted cartridges with Sudhaus chip resetter. Everything was OK. No leaking after refill, etc.
I installed them to the printer and it showed them full (reset successful).When I try to do cleaning checks, nozzle checks, it prints test images without any problems. I can also print normal documents. But when I try to print a photo it gives Error 5100.
After getting this error, I tried my other original cartridge set(not refilled, new) and it prints photos without any problems. It gives 5100 error when I try to print photos with refilled cartridges.
Whan can be the problem?
Thanks for all your help.
tigerwan
B.C.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
