3880 post piezoflush routine?
Umberto Gladys
Epson 3800
Had some issues with my 3880. Basically 3 channels partially blocked. Did the rag with Windex overnight and that helped but still had blocks. Eventually went with the refillable carts and piezoflush. That worked well and now test chart is 100%. All channels show piezoflush on a test print
Question... what is the recommended process to flush all the piezoflush and replace the lines with ink? Is there one command on the panel or via software to get ink back into the system economically or are you just supposed to print test pages until the piezoflush is "run completely" through the system
