Hi there!
Hi Thilo,
Actually the aftermarket chips from aliexpress can be easily reset with your cartridge chip resetter despite it says one time chip only. The one you have is already possible to reset not only original but also aftermarket chips.
Refillable cartridges without chip can be easily found at aliexpress. The cartridges can be used for both the P700 and the P900 A set of aftermarket chips is around 86 euro:
https://nl.aliexpress.com/item/1005...st_main.4.623e79d2D4pTN5&gatewayAdapt=glo2nld
refillable cartridges:
https://nl.aliexpress.com/item/1005...st_main.9.623e79d2D4pTN5&gatewayAdapt=glo2nld
so around 35 euro.
Here is the proof your resetter can reset aftermarket one time chips too:
https://www.printerknowledge.com/th...tters-and-compatible-chips.16994/#post-145221
Thilo
Epson P900, Epson 3880
Hi Thilo,
so around 35 euro.
https://www.printerknowledge.com/threads/epson-p900-–-questions-about-refillable-cartridges-chip-resetters-and-compatible-chips.16994/#post-145221
Dear Nelson,
Thanks again for your kind information! I resettet the chips in my empty original cartrides - now they are recognized in the printer (as "foreign" cartridges). I ordered the empty cartridges via alixexpress and will assemble everything as soon as it arrives. Thanks for helping me out!
By the way, this is my latest report in the forum:
https://www.printerknowledge.com/threads/solved-ink-leak-sensor-error-034831-on-a-sc-p900.17482/
Best, :) Thilo
