Pixma ip7250 strange error after replacement of print head and mother board
AndrewF
Canon Pixma
I have replaced both motherboard and print head of a totally dead printer, placing also new cartridges before power on, but happened this:
printer powered on but power led and resume led flashed alternatively, the printer is not recognized.
I have tried to to hold down power button pressing 5 times resume button because I have heard this enter in service mode and could be helpful, now the printer power on, moves head on the left then power off.
Hogwild
Canon D1350, Canon IP6600D
It sounds to me like the "new" print head or motherboard may be bad. A quick Google found these:
Canon Pixma iP7250 has died. Checked troubleshooting part of​
https://www.justanswer.co.uk/printe...ip7250-died-checked-troubleshooting-part.html
Canon ip7250 Print Head Error​
https://www.printerknowledge.com/threads/canon-ip7250-print-head-error.14490/
When a Canon print head fails it can but does not always damage the logic board in the printer. A logic board damaged by a defective printhead can but does not always damage a new printhead. So swapping printheads between printers for troubleshooting is risky.
This article is not directly related, but may give helpful background info:
Canon Pixma IP7250 - Error 1403: Printhead Temperature Sensor Error, Reset or Bypass Solutions
https://www.elektroda.com/rtvforum/topic3118958.html
The first question I’d ask, where did you buy the mother board and print head, was it through Canon or on EBay ?
AndrewF
Canon Pixma
I was aware of the dreadful design that may cause bad print head to damage motherboard and bad motherboard to damage print head so I have replaced both at same time.
Any suggestion on how to check that printhead is faulty so that I can exclude the error is caused by motherboard?
I haven't any certainly working motherboard or certainly working print head and thanks to the criminally bad Canon idea to make the damage of a printhead to damage motherboard and viceversa I haven't much room for attempts that don't imply damage of good components.
I have a multimeter but no technical details about print head to do a test.
You could remove the printhead and try to turn on the printer. If the printhead is the cause of the problem and the motherboard is OK, the printer will turn on but of course with an error message that the printhead is missing.
You might have to remove the casing and manually unlock the printhead to remove it. Druckerchannel.de has an instruction on dismantling the iP7250 to change the ink absorbers here. And here is how to unlock the printhead. Scroll down to "Druckkopfverrigelung lösen"
Google Translate doesn't always work with links from Druckerchannel.de, but you can use it yourself if you don't read German.
AndrewF
Canon Pixma
As I have said before I have replaced both print head and motherboard on a totally dead printer that didn't power on at all, but now I'm facing these issues because one or both replacement is not good. I have already tried to power without print head and it power off even with no print head at all. The thing that makes me suspicious it may happen due to a not detected print head, is the fact that it moves on left before power off. I don't know if this printer model is supposed to remain on showing a message of missing print head, reliably know this information would be very helpful to guess that motherboard is working properly and it is a bad print head.
Again I ask ?.. where did you source the mother board and print head… :old
oliver666
Canon Pixma G6020
If the power and resume LEDs flash alternately, it usually means a board-head pairing issue. The new logic board and print head need to be matched via service mode reset using Canon Service Tool v5100 or higher. Without that, the printer will not register the head ID.
Music Lover
Brother J1010dw
Your judgment is spot on. The "it shuts down even without a print head installed" test is crucial.
A normal and working motherboard should have the error light on and remain powered on, even without a print head installed, rather than shutting down immediately. This situation essentially confirms that the motherboard you replaced is faulty.
Here are my suggestions:
1. Contact the seller directly and tell them your test results—"The motherboard automatically shuts down even without a print head installed, which is not normal motherboard behavior."
2. Request a motherboard replacement.
3. Don't rush to tinker with the print head or service tools yet. If the hardware itself is faulty, no software fixes will help.
Once you have a working motherboard, use the "power button + restore button five times" method to enter service mode. Use the repair software to clear the EEPROM, and you should be able to revive the system.
Sincerely hope it could be helpful.
