HungTR
Canon Pro 1000
i didn't do a nozzle check before the target, my machine is still working daily and not on idle, i just execute a nozzle check and it is fine. thank you i will be waiting for the new target, and i saw the post on jtoolman group about you sizing the target in photoshop for the i1studio could you explain that to
  • 480-patch.zip
  • ArgyllCMS Colormunki 325-target.zip
HungTR
Canon Pro 1000
does the 350 patch create a good enough profile or the 480 patch is still the magic number
Modern RGB printers are pretty linear in behaviour, so there is not much difference between 325 and 480 patches, but for shadow details a larger patch size can certainly help. Just give it a try and see what does better: 480 vs 325 patches.
HungTR
Canon Pro 1000
This is the chart after i scan both 480 and 325 profile. In the scanning process there are still warning about DeltaE on both patch but the final test image are the same just a little brighter on the 325 profile other than this it the same
Take into account measuring errors. Like I have said there is little difference visually in prints, which you want to have. But have good look at the shadows (not crushed) if there is any difference when printing the same picture.
