TS8350a 5B00 - looking for solutions
GlassCANON
TS8350a
Hey all,
My Canon TS8350a is showing the 5B00 error. Since this is my second printer of this model dying due to this issue, I’d really like to know if anyone has experience solving it. I don’t want to throw away another printer.
I found that the Canon Service Tool v6400 might be able to reset the waste ink counter, but for this model, the only available versions seem to be sold by foreign eBay sellers, with no guarantee that they work on this particular model. I contacted one of the sellers, but unfortunately, they weren’t very helpful.
Has anyone tried a version of the tool on the TS8350a successfully and can share their experience?
Thank you!
I don’t know where you got your information from, but the Service Tool v6400 most lightly won’t work, you’ll need a higher version to be sure..
But if you want to take the chance here it is..
Just change the file extension from zip to exe to use..
  • Service tool v3400.zip
GlassCANON
TS8350a
Thank you for your answer!
I thought the v6400 is a pretty recent version of the tool, but seems to be not not publicly available. The tool you provided also appears to be another version.
But I hardly can find any information about the supported printers and do not want to spend 30 Dollars on some eBay-tool that is not verified to work. If it works guaranteed I am gladly spending that amount!
Most likely I'll get a TS8750 as a replacement, even though I absolutely hate to buy another one of those Canon printers without a replaceable waste ink container.
If I reconcider it now is the 4th or 5th printer being replaced for that reason, but the person the printer is going to is really used to the Canon software, so changing the brand is not an option.
Artur5
Kmt. 0.
Three years ago I purchased from the same Ebay seller the service tool v5.306. It works fine on my Maxify. As PeterBJ says, for your TS8350 you'll need a newer version,
One minor caveat is that you have to register the service tool. The vendor sends you a key file, valid only for your computer. It won't work on a different machine. That makes sense, because the vendor needs to protect his sales from piracy, but if you replace your computer in the future, you'd have to purchase that service tool again.
GlassCANON
TS8350a
You find no free downloads of newer Canon service tools, but version 6.000 is also claimed to work with your printer. Here is an eBay offer at 7$. I would spend the 7$ before giving up and buying a new printer.
Thank you!
The issue I have is that the TS8350a is never in those lists and the sellers can not say if it works or not for those as well.
But I'll give it a try, a TS8350 non a is also sitting around with the 5B00 error. It is a plague and the broad majority of people, including myself, do/did not know about the possibility to reset that counter. Unfortunately all my older models like the iP4950 are already sitting at the scrapyard.
Thank you for sharing your experience!
Ok, so I'll have to consider what PC to use it on so it sticks around for the future.
But without knowing how the distribution of the service tool actually works I'd say all of those tools are pirated Canon originals, or?
Artur5
Kmt. 0.
Your guess is as good as mine. An inside job ?. I'd say that, if it were so, Canon is rather sloppy protecting themselves from internal "leaks". Or is it Canon openly selling this stuff to third parties ?.. or clever hackers doing reverse engineering ?. Whatever might be, service tools have been there for a good number of years..
GlassCANON
TS8350a
Ok. But I'll give it a try before buying another printer. 7 or 8 dollars is way better than 150+ for basically the same printer, since the TS8750 offers almost no benefits compared to the TS8350a.
