- Apr 19, 2007
- USA
- Canon MB5120, Pencil
I thought you only had to do that in Australia.Turn both the cart and the resetter upside down
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I have tested 9500 and Pro 10 carts till I was blue in the face and I stopped refilling one after 50 refills, just to see how durable they were at standing up to regular refilling.Possibly Pro10 and Pro9500 carts aren’t 100% the same size ?. My totally empty PGI-72 carts with bottom clip weight 18.0gr. Properly refilled should be around 33 gr. Exception is chroma optimizer which is 32gr. being less dense than regular colors.
I'm not optimistic at all about that resetter. I believe is kaput or it wouldn't have damaged the second PB chip.
A tube of toothpaste will too but not the point. The scenario is a cartridge that leaks with only gravity and not some other applied force.in my experience, even PGI-72 cartridges not totally full, will drip a bit if you squeeze them.
Now, in most Internet sites people are assuming that 14ml of ink= 14gr and this isn’t exactly the case. I measured the density of Octoinket Pro10 inks at 1.06-1.07 gr/ml for regular colors and 1.00 gr/ ml for Chroma. Therefore, 14ml of regular ink weight around 15gr. and 14ml of Chroma are 14 gr. Other ink brands might be slightly different but not much, I guess.
Like you, my carts declared empty by the driver weight at least 20-21 gr. I wouldn’t criticize Canon for being over cautious. Better being safe than sorry and, if we refill, no ink is lost. Of course, people using single use cartridges waste 10-15% of the ink.
