- Jan 18, 2010
- Residing in Wicklow Ireland
Turned on my Pro 9500 yesterday morning and it went through its usual start-up routine but then it stopped abruptly with the Big red notice of B200 error warning displayed.
I turned off the printer again and I could pull the print head out from the parking station, I could also remove the cartridges but not the print head, the print head carriage was stuck in the down print position and wouldn’t allow the head to be removed.
I Figured it was time to pull the top cover off and see what had cause the problem in the first place, well it didn’t take long to notice the wiper and blades had de-thatch themselves from it’s position with bits of it all over the purge unit and one piece was stuck under the print head.
I carefully removed all the pieces I could see and then rotated the gears to enable me to remove the print head by raising print carriage up a little bit.
It was obvious that if I was going to attempt fix the wiper unit and blades then the purge unit would have to be remover and this would also assist me in finding the remaining missing pieces.
I managed to locate all the wiper unit pieces, then with an awful lot of cleaning I managed to get most of the ink off so I could see where everything was suppose to go, I had a lovely clean purge unit.
With the help of some photos that I had taken from a previous encounter with a purge unit repair, I was able to put all the pieces back in the correct order and glue them into their right position, I used EVO-STIK Rapid Metal hardener.
I carefully put the purge unit back into the printer and assembled all the bits I had removed to gain access to it and then put the top cover back on again.
I switched on the printer and everything looked and sounded fine then I installed the print head followed by the cartridges and Wham same Error B200 appeared, so I tried removing the cartridges and head once more and you guessed it, the head wouldn’t come out !
I removed the top cover AGAIN and pulled the head out, powered on the printer and it was sounding good with no errors this time, so I put an old spare damaged head in that I had and the printer accepted it and worked properly, Top cover still off at this stage.
So I pulled out the carts and print head and put back in the original head again and the same B200 error occurred, so it was time to try another approach, may be the head got damaged from hitting the wiper unit blade assembly ?
I put a third print head (Damaged) in and it work fine also, then I put the first damaged head that had worked previously in and it too worked fine and finally I put back the original head in and it worked with no carts in but once I installed all the carts then the B200 error reappeared.
The final outcome to it was to install a print head from my other 9500 and reassemble this printer again and it’s now working away like nothing ever happened to it, so it’s now time to purchase yet another new head.
I will do another thread later with photos and an update on the dissembling of the purge unit with something else that I found while poking around there..
