- Apr 19, 2007
- USA
- Canon MB5120, Pencil
Thanks for the videos! Great job getting your points across and the image quality is as needed.The videos take HOURS to load.
Here are the first ones loaded. More and more interesting ones will follow. These first two are the fundamentals of what to know.
http://www.precisioncolors.com/Maintenance_Canon.html
Watched the first 4 videos. The 4th one seems to end abruptly at 5:09. Is this the end? There is also a potential error in the 4th video beginning at 1:37 -- do you mean to say "when the printer says EMPTY"?
The 5th video is a link to a PDF at this time.
Concerning your theory on foam causing ink flow issues, it sounds reasonable. A couple points:
1) Your sucking up from and refilling the ink only into the reservoir ALONE does not produce foam in the cartridge since no ink is redistributed from the sponged side. I get your point but the foam you created is by the action of the syringe causing turbulence in the fluid.
2) The foam will resolve, at least for the most part. This occurs in the reservoir and there is no reason to think otherwise in the sponged side unless you have data to the contrary. Empirical evidence support my theory based on the fact I have seen foam resolve in the reservoir in a short time, and, a cartridge that is not taking up the ink in the sponged side will improve if let to sit.
3) Foam does not, at first blush, explain how a sponge that appears to have sufficient ink may still result in ink flow problems that a flush will resolve.
4) I do not recall a sponge that behaved in the extreme as you demonstrate and I always print until one cartridge is marked as empty. Then I refill all the cartridges except maybe for the Pigment Black if there is plenty in the reservoir when a dye-based cartridge runs empty. I have not flushed a cartridge in years and have been using one set of cartridges only for same time as well. I do not remember how long because there haven't been issues for a long time. (knock on wood) I also use CLI-8 / PGI-5 cartridges and refill via the Durchstich method as does Jimbo123 and we have been relatively issue free. Jimbo prints boatloads. I do not but I do print something that uses all the cartridges once a week, or at least most weeks.
All in all, I do like your theory of foam as a causative agent in ink flow problems. Looking forward to video #5. Please let us know when it is up for our viewing pleasure.
