- Jan 18, 2010
- Residing in Wicklow Ireland
I had been asked by @palombian to test out a brand new pigment ink-set made in the EU and I used my PGI-9 cartridges and the initial results look very promising.
While the inks work perfectly well and the colours look smashing, it was some time later that I couldn’t get a good ink flow from the print head again, it was like the ink inside the heads had simply dried up in minutes.
This problem looked very similar to the “Yello Jello” strike I had when I was using a CLI-42 cartridge, resulting in the output of the yellow ink been reduced by anything up to 90%.
I had no difficultly reverting back to my old inks and the print head was not damaged from running a couple of dozen test prints while the yellow nozzles were clogged, the dried ink somehow stopped the heads from overheating.
This maybe a one off but I honestly don’t know so it would be advisable to keep that in mind especially if you intend to refill your own Pro printers, maybe this ink was not intended for use in the PGI-9 cartridge !
This is not a scare notice more of an advisory one so please stay alert to all the new changes in today’s market place..
