- Thread starter
 - #11
Soporose
 - Dec 2, 2006
Well folks, that last post was just on a year ago, and now I'm back to report that the problem still has not been resolved!
Why so long?
I was away for several months right after that last post and left my PC & printer in the hands of a relative, as I had a laptop to use while I was away. Then when I got back they had plugged in an ancient parallel port scanner rescued from a junk pile, which has continued to work up until recently.
So now that the old scanner has gone to tech heaven I'm back where I started. I hunted down this thread again, and followed the various instructions given.
I've replaced the long USB cable with one about 1.5 metres in length, and tried bypassing the hub by plugging the printer's USB cable directly into the last working USB port on the PC.
Still no joy.
Apart from scanning, everything else seems to work fine, and I can do Copies from the printers LCD Control Panel. But if I try to do a Scan from the LCD panel, there is no movement of the scanning head or any other sign of physical/mechanical activity.
After I select Scan from the LCD screen it reads...
So I hit either Colour or Black to start scanning.
After 30 seconds (seems like a long time, but I timed it) the LCD screen returns to the display described above. There is no physical activity of the printer during the "Processing" time.
I'd just as soon not reinstall all the Canon software again. I was wondering if the scanning software is separate and I could just reinstall it. Can't find the original CD but I believe all the drivers are available online.
			Why so long?
Still no joy.
PC
Local (USB)
Doc.type Auto scan
[White & green icons] Scan
Save/Forward
Local (USB)
Doc.type Auto scan
Save/Forward
Processing...
Please wait momentarily.
