- Apr 19, 2007
- USA
- Canon MB5120, Pencil
The OP's purge test with flooding the purge pads and then doing a cleaning cycle is indicative of what then? Working or not working purge system? Is the purge system ruled out as malfunctioning or not?Unfortunately, prior to my complete understanding of how this works, I gave out a lot of incorrect advice for the MP780 and iP4000 printers, that you could easily tell if your purge unit was clogged by putting Windex or water on the purge pads, closing the lid and re-opening it to see if the liquid had been sucked away. That's how it worked on most of my printers, which, in fact, had that second tubes clogged and not the tubes going to the purge unit. If you do that little exercise, it should not clear the pads. If it does, it means those extra tubes are clogged. So if the pads are not cleared, it could be because your printer is working correctly or the purge unit is clogged. The correct test is to do a cleaning.
It turns out that if those extra tubes are clogged, your printer can still purge the print head and it can work properly but it will dump a lot more ink into the waste tank and not keep track of it so you can have an overflow of your waste tank before the printer warns you of the possibility, especially if you are putting a lot of Windex or water on your pads regularly just for preventative maintenance. That happened to me on one of my printers. When I lifted it up for an unrelated reason, I discovered that it was hiding a pool of black ink under it.
Is this like the Karate Kid movie where Mr. Miyagi instructs Daniel to "wax on, wax off" but without the reason why?
