- May 29, 2007
- Ghent, Belgium
- SC-900 ET-8550 +18100 WF-7840
@itsab1989 /AI Agent: I am thinking about a possible solution of differentiate between paper white and jig surface white is to begin a row with a triple spacer: black-white-black followed with the patches + corresponding black/white or coloured spacers and ending again with triple spacer black-white-black. This will only adds a slight amount of length the row, but I think ArgyllCMS can detect this triple spacer change as a trigger to begin and end register the data from the measurement and omitting anything outside this given boundaries, as the change of delta-E between paper white and jig surface white can be seen as a spacer (adding an additional patch to the reading). By using this triple spacer method, ChromIQ can easily determine which data must be taken into account for the measurement and thus it can omit the data read before and after these triple spacer markers as the boundaries of the data used for ChromIQ.
However this would probably cause problems with cross-application targets (ChromiQ versus i1Profiler), thus the system must automatically generate a duplicate target too when one would check the option to make the necessary pxf/mxf/txf data for the corresponding i1Profiler target set, where those triple spacers are substituted by the standard single black spacer.
