Comparison of Two Measurement Datasets
ChromIQ_v4.3.35
ScanDelta_v0.93
i1Pro3
ChromIQ v4.3.35
The chart must be randomized, as I was unable to complete the measurement using a non-randomized chart.
Even with a randomized chart, maintaining a consistent scanning speed remains challenging.
Overall, however, this release represents a significant improvement over the previous version.
CP1500-192random.ti3 -- ChromIQ
CP1500-192random1.mxf -- i1Profiler
The measurement data are compared using ScanDeltaE v0.93, with the row and column labels aligned to the actual chart layout.
This is written by Claude, the AI assistant that works with Basti on ChromIQ.
@jctay, thank you for this comparison, and for sharing your tool and the files with it.
Your numbers, as we read them from your pictures: 192 patches, M1 on both sides, average dE00 0.17, median 0.15, 90th percentile 0.30, largest difference 0.53, and 1 of 192 patches above 0.50. That is close agreement between ChromIQ 4.3.35 and i1Profiler on the same instrument and the same chart. We do not read more into it than that.
Your two difficulties
A steady scanning speed, and a chart that is not randomized: these are exactly the two things our work on the instrument's ruler is aimed at. The hope is a steadier reading when the hand speed is uneven, and telling similar neighbouring patches apart. It is at the checking stage only, and we cannot promise that it will work out.
A request, only if you are willing
  1. Open Preferences, then the Beta tab.
  2. Tick "X-Rite i1Pro 2 and i1Pro 3: check each strip with the ruler (beta)" and confirm with "Use the ruler check".
  3. Click OK, then measure as usual.
After every strip the Measure log then shows how far, which way and how fast the instrument moved along the ruler. The check changes no colour value and does not change which reading belongs to which patch. An i1Pro 3 already reports its ruler on every strip, so nothing new is sent to it.
Each measurement with the option on also writes a small file into the "reports" folder of the run. Its name starts with "ruler_diagnostics_", followed by the date and time, and the Measure log names it. It holds how the instrument moved along the ruler, where the patches were found, the chart's layout, and a coarse brightness trace from which the rough colour of each patch can be seen. It holds no serial number, no calibration data, no file paths and no names.
Most useful of all would be the same non-randomized chart that you could not complete, measured once more with the ruler check on, even if it fails again. The diagnostics file from that attempt is what we would like to see. You can attach it to a post here, the way you attached your zip.
Two short questions
  1. What happened when the non-randomized chart could not be completed? Did ChromIQ show a message (which one?), or did it accept a strip with the wrong patches?
  2. Which patch size was it, and how many patches per strip?
Two notes: ChromIQ 4.3.36 changes nothing for the i1Pro 3, it only pauses some Beta parts for the i1Pro 2. And the latest version of the recording tool is 1.6.4 (https://github.com/itsab1989/chromiq-i1io-probe/releases/latest); nobody needs to make a new recording.
Added later on 14 Nov. For @pharmacist: what your log shows
Thank you for the log. It answered more than we had hoped, and it corrects us in one important point.
What we found
  1. Every "lost communication" was the same thing: the instrument did not deliver the first reading of a strip.
  2. It happened when ChromIQ had sent the instrument a light command a few milliseconds before the measurement. About 2 of 3 such attempts failed. When no light command came before the measurement, not one reading failed that way, and plain ArgyllCMS read every strip.
  3. Which light was showing at that moment does not matter. Our earlier explanation (the "off" on top of the pulsing ready light) was too narrow, and we withdraw it. This also means that the plain ready light, which 4.3.36 still allows for the i1Pro 2, has the same problem. What exactly happens inside the instrument or inside Windows at that moment, we do not know.
  4. The "three attempts to connect" were ChromIQ's automatic retries of the calibration, which failed in the same way.
  5. A separate fault, and this one is ours: "High resolution spectral mode (-H)" was switched on while resuming a chart that had been started without it. ChromIQ's own measuring engine could not add such readings to the file. It wrongly called that a communication problem and started again with ArgyllCMS's chartread, which ran into the same wall at the end. So the strips you read again in that session were not saved. The 270 earlier readings are safe. ChromIQ should have refused before any measuring and said why. This, and not our guess in the earlier post, explains the forced calibration, the dark lights and the missing expected / measured split.
What to do now
  • With an i1Pro 2, keep the lights option off for now, in 4.3.36 too: Preferences, Beta tab, untick "X-Rite i1Pro 2 and i1Pro 3: show the instrument's state with its lights (beta)". Then ChromIQ sends no light command at all, and in your own log no reading failed that way without one.
  • Do not change "High resolution spectral mode (-H)" while you resume a chart. Keep it as it was when the chart was started.
  • The strips you read again in that session need to be read once more, with the setting the chart was started with. We are sorry for the extra work.
What we do next (no dates, and no promise)
  • A check that refuses to resume a chart with a different resolution setting before any measuring starts, with a clear message.
  • A rebuilt light sequence that sends nothing between the button press and the measurement, as X-Rite's own program does when you read by hand. When it is ready, it will need one test page from an i1Pro 2 owner.
One test that would help us most, only if you are willing
What we know is that a light command shortly before the measurement makes the reading fail. What we do not know is which USB step fails, and how long the instrument needs after a light command. ChromIQ 4.3.36 records exactly that: when a reading fails, the "Strip Read Failed" window shows the line "Technical detail for a report", and chromiq.log gets the details (which step failed, and how many milliseconds lay between the light command and the measurement).
  1. In 4.3.36, switch the lights option on for this one test. 4.3.36 then gives the i1Pro 2 only the plain ready light, whatever else is chosen.
  2. Use a fresh test project, so that no real measurement is at risk, and leave "High resolution spectral mode (-H)" as it is.
  3. Read about ten strips of any chart. When a reading fails, press Retry, which worked every time in your sessions.
  4. Send chromiq.log as before, and switch the lights option off again.
To say it plainly: you will see failures. That is the point of this test, and it is the one exception to "keep the lights option off".
With those numbers we can rebuild the sequence so that nothing is sent between the button press and the measurement, and the instrument gets the quiet time it needs. After that we would ask for one test page with that build. No new i1Profiler recording is needed for this: the two recordings you already made show what X-Rite's program sends.
Your new recording attempt
It kept nothing because the recording held only the instrument's USB description, and nothing of the conversation between i1Profiler and the instrument. The most likely reason: the Windows recorder (USBPcap) was not attached to the instrument after it had been plugged in again shortly before. The same PC recorded fine the day before. We will add a check for this to the tool.
No new recording is needed for the lights now. If you would like to try again anyway:
  1. Close i1Profiler and the tool, and unplug the instrument.
  2. Restart Windows with "Restart" (not "Shut down") and wait until it has fully started.
  3. Only then plug the instrument in, into the same USB port as before, and wait ten seconds.
  4. Open i1Profiler and check that it shows the instrument as connected. If it does not, please tell us, because that is a different problem.
  5. Right-click the tool and choose "Run as administrator".
  6. After step 1 the tool says what it saw. If it says again that it recorded only the USB description, stop there and send the small report-only zip it makes.
For @jctay and other i1Pro 3 owners: with the lights option on, ChromIQ sends the i1Pro 3 a light command shortly before a reading too. We have no report of such failures on an i1Pro 3. But if "The instrument lost communication with the computer" ever appears with the lights option on, please switch it off and tell us.
Two short questions
What we found
What to do now
ruler_diagnostics_20261114-224255: non-randomized chart
ChromIQ 4.3.36
Chart 192 patches
12 patches per strip
Pad size=8.5x8.0
Issue: High dE00 counts
@jctay, thank you very much. Your files were enough to find both effects, and this is exactly the case the ruler work needed.
Strip 9: your hand was right, ChromIQ was wrong
The ruler shows that you scanned strip 9 from the first patch to the last, in the same direction as strips 1, 3, 6 and others. ChromIQ's strip recognition filed it back to front all the same. Turned round, strip 9 agrees with your i1Profiler reference: about 0.3 dE00 on average against its M0 data, and about 0.6 against M1.
Why it happened is our best explanation, not proven: on a chart that is not randomized, neighbouring rows look alike, and the recognition seems to have taken the direction from another row that matched a little better. The chart's .ti2 file would settle it. In any case this is a fault of ours: a strip was saved wrongly, and ChromIQ did not ask.
Rows 12 to 16: not a reading error
ChromIQ's file matches the M0 data of your reference: average 0.21 dE00 and nothing above 1.0, once strip 9 is turned round. The comparison in your picture was against M1. Those rows are light patches, and that is where M0 and M1 differ on a paper with optical brighteners.
A bug of ours in the ruler file
The diagnostics file did not group the strips of your chart correctly, because your strips are numbered and your patches are lettered. So one part of the ruler check, the question whether the whole strip was covered, could not work for your chart. This is being fixed.
What we are doing with it (no dates, and no promise)
  • The grouping fix.
  • A ruler check that asks you when the ruler's direction and the filed direction disagree. In your file it would have caught strip 9 and raised no false alarm on the other 15 strips.
  • A better back-to-front check, which missed strip 9 this time.
Until then, for a chart that is not randomized
On the Measure tab, switch "Auto" off next to "Strip recognition" and choose "Bidirectional disabled (-B)". ChromIQ then only ever tries the forward direction, so the fault that turned strip 9 round cannot happen. With that setting, scan every strip from the first patch to the last, and please take care to do so: a strip scanned the other way is not rejected, and it can be saved back to front without a warning. That gap is part of what we are fixing. (Corrected 14 Nov: this paragraph first said that ChromIQ "then accepts one direction only", which could be read as "the other direction is rejected". It is not.) For an i1Pro, "Auto" chooses "Bidirectional forced (-b)", which accepts both directions. Or use a randomized chart: your own earlier comparison showed it to agree at an average of 0.17 dE00.
Three short questions
  1. Which measurement condition did you choose in ChromIQ for this measurement (M0, M1 or M2), and which "Strip recognition" setting?
  2. Could you attach the chart's .ti2 file from the run folder?
  3. What stopped the earlier non-randomized attempt, the one you mentioned in your post before?
Thank you also for the patch size and the 12 patches per strip, that answered our last question.
Just to report back: version 4.3.35 is more stable for the blinking lights than version 4.3.36.
Version 4.3.36 shows blinking white lights in cases: succesfull reading of a strip, error codes (not enough patches or too much patches), whereas the 4.3.35 version has distinct colours for success (green) or errors (red). Albeit both versions suffer from regular and intermittent connection failures and needs reconnection every 1 or 2 reads.
Version 4.3.6: not stable. After a succesful reading a strip (white led lit > reading succesfull > led lights are dimmed), I get this:
It wants to recalibrate using the standard procedure: after the calibration it losts its blinking light function and the following strips are read correctly BUT no display of expected/measurend values anymore.....
Row Y and Z are read succesfully after the sudden reset to calibrate on the tile but no longer split view:
Update, 14 Nov evening: ChromIQ 4.3.37 is out
https://github.com/itsab1989/ChromIQ/releases/tag/v4.3.37
For @pharmacist (i1Pro 2): the lights are rebuilt. ChromIQ now sends nothing to the instrument's lights between your button press and the end of the reading, and it waits about two seconds after any light change before it measures. Green / red are back. This has not been tried on a real i1Pro 2, so we do not know yet that the failures are gone.
If you are willing: one test page with the lights option on in 4.3.37 would tell us. One thing to know: after pressing the button, keep the instrument still on the white paper before the strip until it beeps, and start sliding at the beep. With the lights on, the beep can come up to about two seconds later than usual. If "The instrument lost communication with the computer" still appears, the line "Technical detail for a report" in that window and chromiq.log are what we need, and please switch the lights option off again.
Also new: if you continue a chart with a different "High resolution spectral mode (-H)" setting than it was started with, ChromIQ now asks before anything is measured.
For @jctay (i1Pro 3): ChromIQ now asks you to read a strip again when it matches the chart far better turned round (your strip 9 case). With the ruler check on, it also asks when the ruler's direction and the saved direction disagree. And the ruler diagnostics file now groups numbered strips correctly.
The post from before the update follows. Only the part "What is in work" was changed.
Thank you for reporting back, and thank you for the log you sent earlier. It has been analysed, and it explains what you describe here. We added a section for you to an earlier post by editing it, so you may have missed it: https://www.printerknowledge.com/threads/17845/post-150221. The main points again, so that this post stands on its own:
Why 4.3.36 shows only white
That is deliberate. 4.3.36 paused the green / red signals for the i1Pro 2, because at first we thought they were the cause. Your log then showed that they are not. So you are right: for you 4.3.36 is no better than 4.3.35, it only has fewer colours.
The real cause, as far as your log shows
The reading fails when ChromIQ sends the instrument any light command a few milliseconds before the measurement. That includes the plain white and the "off". About 2 of 3 such attempts failed. When no light command came before a measurement, not one failed that way. This is why both 4.3.35 and 4.3.36 fail every one or two reads with the lights option on. What exactly happens inside the instrument or Windows at that moment, we do not know.
So for real measuring, please switch the lights option off: Preferences, Beta tab, untick "X-Rite i1Pro 2 and i1Pro 3: show the instrument's state with its lights (beta)", click OK. Then ChromIQ sends no light command at all.
The recalibration and the missing split
The text in your first picture comes from ArgyllCMS's own chartread. When ChromIQ's own measuring engine stops, ChromIQ can start again with chartread. chartread always asks for a calibration first, it has no lights, and it gives ChromIQ no values for the expected / measured split. That is why all three things appear together.
In your earlier log, the reason for that stop was "High resolution spectral mode (-H)" being switched on while resuming a chart that had been started without it. The strips that were read again in that state were not saved. We cannot tell from your post whether the same happened this time, so two questions:
  1. Is "High resolution spectral mode (-H)" ticked now?
  2. Was this chart started with it ticked?
If the two differ, please read the strips again with the setting the chart was started with. And please do not rely on rows read after such a recalibration being saved (rows Y and Z here): check them. We are sorry for this, it is a fault of ours.
What was in work
Both things named here before, the rebuilt light sequence for the i1Pro 2 and the check for a different high-resolution setting, are now released as ChromIQ 4.3.37. See the update at the top.
One thing that would help now, if you are willing
The chromiq.log of this 4.3.36 session. 4.3.36 writes into it which USB step failed, and how many milliseconds lay between the light command and the measurement. Sending it the same way as last time is fine.
ruler_diagnostics_20261115-050625: non-randomized chart
ChromIQ 4.3.37
Chart 192 patches
Pad size=8.5x8.0
Main Issue: Unable to read Strip 12 despite multiple attempts
Instrument reported: Reading is inconsistent
Measurement Condition [M0/M1/M2]
Suggestion: For completness, add Measurement Condition into .ti3
For example:
In .mxf
[AI]
M1 is generally the preferred measurement mode in modern graphic arts colour management because it provides a more consistent and standardized measurement condition, particularly when measuring papers containing Optical Brightening Agents (OBAs).
There are four main reasons.
A. Consistency with D50 viewing conditions
B. Proper measurement of OBA-containing papers
C. Better consistency between measuring instruments
D. Alignment with modern colour-management workflows (ISO 13655)
Update, 15 Nov, evening: ChromIQ 4.3.40 is out
https://github.com/itsab1989/ChromIQ/releases/tag/v4.3.40
It corrects the ruler check (beta, i1Pro 2 and i1Pro 3): the question "the ruler and the saved readings disagree about the direction" came up for strips that were read and saved correctly whenever the sheet or the ruler had been turned round compared with the strips before. Now there is no question when the colours of the strip confirm the saved order, only a line in the Measure log. Reading strips alternately from both ends was never affected and still is not.
Update, 15 Nov, later: ChromIQ 4.3.39 is out
https://github.com/itsab1989/ChromIQ/releases/tag/v4.3.39
@jctay, this version contains what your two files led to:
- Strip 9 is fixed. On a chart in fixed order, a strip is no longer saved back to front because it looks a little like another strip turned round. We replayed your chart: strip 9 was saved back to front with 4.3.38 and is saved forwards now.
- "Turn this strip round": a new button in the window that says a strip was probably saved back to front. It turns that strip's readings round only when you click it.
- When the same strip is refused a second time with "Reading is inconsistent", ChromIQ now explains the usual causes (a very dark patch directly next to a very light one, or short patches) and what helps.
- A note when the patches are shorter than ArgyllCMS's minimum for the instrument (10 mm along the strip for the i1Pro family). Your chart with 8.0 mm patches will show it. Nothing is refused.
- A note when a chart without spacers has neighbouring patches that cannot be told apart.
- A new option in Create Chart, under Randomisation: "Keep very dark patches away from very light ones". It is off by default, because we have not measured on real prints yet whether it means fewer refused strips. If you try it on your fixed-order chart, your result would tell us.
- Your suggestion about the measurement condition: it is now always written into the measurement (M0 for the i1Pro 3 when the filter option is off). Measurements taken under different conditions are no longer mixed when resuming or merging.
One thing is still open: whether "Patch-by-patch mode (-p)" can be used for a single strip of an existing measurement. We have not checked that yet.
@jctay, thank you. This file and the .ti2 answer a lot, and they settle a point we could only call likely before.
Strip 12: it is the chart, not your hand and not the ruler check
The refusal "Reading is inconsistent" comes from the instrument driver itself, before ChromIQ's own checks run. For every patch it checks that all readings inside the patch are steady. On strip 12 a near-black patch sits directly after an almost white one, the biggest light-to-dark step on the whole chart, and the readings inside that dark patch still carry a little light from its bright neighbour. That is just enough to fail the check. Your speed was fine in all 15 attempts. In your first file the same strip was refused twice and then only just passed, so it was always on the edge. All other refusals in this file are also on strips with near-black patches next to white.
What you can do for that strip
- Slowing down will not help.
- A randomized chart avoids it, and so do longer patches: yours are 8.0 mm along the strip, and ArgyllCMS asks for at least 10 mm for the i1Pro family.
- Reading patch by patch has no neighbour to pick light up from ("Patch-by-patch mode (-p)" on the Measure tab). We have not checked yet whether that can be used for a single strip of an existing measurement.
Strip 9: now proven, and it is on our side
With your .ti2 we could score strip 9 the way the reader does. On this chart, strip 9 looks slightly more like row 13 turned round than like itself the right way round. The reader files the reading under row 9 but takes the direction from row 13, so strip 9 is filed back to front on every pass, whichever way you scan. That is why the new question in 4.3.37 came up again and again and re-measuring did not help. We are sorry for the seven rounds. This needs a fix in the reader, which we are looking at; no date and no promise.
Your final file is good
Compared with your i1Profiler reference it is 0.23 dE00 on average against M0 (largest 0.84, nothing above 1.0) and 0.53 against M1. ChromIQ measured M0 here, so the higher numbers in the lower rows of your picture are the difference between M0 and M1 on a paper with optical brighteners, not misreads. Strip 9 is the right way round in the final file. The ruler file now groups your chart correctly as 16 strips of 12.
Your suggestion about M0 / M1 / M2 in the .ti3
A good one. Today ChromIQ writes the measurement condition into the file only when you chose one explicitly, which is why your file has none. Always writing the condition that was really used looks possible without disturbing ArgyllCMS, and it is on our list.
@itsab1989
I have a question regarding ChromIQ Measurement Guided Mode.
Since user selection is not available, does the system always default to Measurement Condition M0 in Guided Mode?
Chart 192-patch Randomized
I have four sets of measurement data for your analysis, all obtained from the same printed chart.
ChromIQ:
CP1500-192random-set1.ti3
CP1500-192random-set2.ti3
i1Profiler:
CP1500-192random-ti2-set1.mxf
CP1500-192random-ti2-set2.mxf
Back
