[Tool] ChromIQ – a macOS and Windows GUI for ArgyllCMS printer profiling (v3.9.0)
pkk
St. Louis Mo.
Canon Pro100 Epson 3880, 9880
@pkk can you give me your ti1 file you uses for your 468 patch target so I check whether it is a configuration error or reading problems ?
Yep. Attached.
  • Arg468_Pro1000_RRPremiumGloss (2).zip
I just generated the test profile using your 468 patch ti1 file and this is the softproofing:
Seems to be perfectly ok to me: conclusion it is caused by reading errors.
This is the profile in iccview.de:
perfectly rounded profile without strange indentations like the previous one.
  • Testprofile_468.zip
OK, just finished the large new designed 1944 patch target using the latest patch generator algorithm to get a better TC9.18 target.
The new workflow files for ChromIQ/ArgyllCMS is optimized for the i1Pro scanning table: just insert the sheet completely onder the paper clamp towards the right border of the table (fully inserted) and have ergonomical scanning experience.
This is the softproofing to test if the workflow is functioning/correct or not:
Seems to be perfectly OK, so I will send the workflow files to @itsab1989 to be integrated in ChromIQ
itsab1989
Epson ET 8550, Canon Pro 300
Done. Expect the new release in a few minutes. Thanks a lot!
While adding the presets I found a little gap. Although the charts are visibly randomized they did not get the correct tag so that chartread would recognize them as such (affects the bi-directional reading). I corrected this so they are now tagged correctly and should read bidirectional with Argylls / chartreads default settings.
We seemingly also found the cause of the missing tag and fixed it. So for the future this should hopefully be no issue anymore.
itsab1989
@pharmacist
To be sure the preset works as expected could you load the new preset in the updated app and re-measure your already printed chart? That way we can that the tag that was added afterwards does not cause any issues.
pkk
St. Louis Mo.
Thanks, pharmacist. I'm going to play with the function that allows you to reread just a problematic line. That is a great feature.
itsab1989
Well it depends on whether it actually works. But thanks for the compliment. This is one of the features that if it works I am particularly pround of. Because as a beginner in this whole topic who created his first printer profile with Argyll in february this year I ran into the same issue. Knut gave me the tip to make a completely new measurement of only the affected strips, then manually open the ti3 files and copy the values fron the new to the original. This worked but was pretty cumbersome. So I was happy when I figured out a way to automate this ;)
@pharmacist
Everything OK, see mail I have send you.
