[Tool] ChromIQ – a macOS and Windows GUI for ArgyllCMS printer profiling (v3.0.0 beta 10)
itsab1989
Epson ET 8550, Canon Pro 300
Hey everyone,
I’d like to share a small project I’ve been working on:
ChromIQ – a macOS app that puts a graphical interface around ArgyllCMS for creating custom ICC profiles for RGB inkjet printers.
The motivation was simple:
ArgyllCMS is excellent, but chaining targen, printtarg, chartread, colprof and profcheck from the command line is a real barrier. ChromIQ tries to remove that friction with a guided five-step workflow:
1. Create chart – guided mode looks up the optimal patch count for your instrument and paper size from an empirical database and sets sensible defaults automatically; manual mode exposes all targen/printtarg parameters directly
2. Print chart – sent directly to your printer via CUPS, bypassing ColorSync to avoid any colour management interference during printing (this part still needs some work)
3. Measure chart – drives chartread with your spectrophotometer; the app handles calibration prompts, strip navigation, wrong-strip warnings, and retry dialogs so you’re not staring at a terminal
4. Build profile – runs colprof with the full option set including FWA compensation, gamut mapping and rendering intent overrides
5. Check & Refine – runs profcheck on the finished profile, shows per-patch ΔE results, and lets you selectively re-measure only the worst-performing patches with guided strip-by-strip instructions
Supported instruments:
X-Rite i1Pro 1/2/3, i1Pro 3 Plus, ColorMunki, i1Studio, SpectroScan.
Runs on macOS 12+, Apple Silicon and Intel (universal binary).
Honest caveat:
The project is only a couple of days old. The core workflow runs end-to-end and a number of early issues have already been fixed, but I haven’t been able to test every printer, paper and instrument combination out there. There will be edge cases I haven’t caught yet.
I’m sharing it because I spent a long time looking for something that covered this workflow properly and came up empty. If it helps anyone who’s been stuck at the same point, that’s reason enough.
GitHub: https://github.com/itsab1989/ChromIQ
Any feedback – what works, what breaks, what’s missing – is very welcome.
A big thank you to @soul-traveller – your script pointed me in the right direction, and I’ve learned a great deal from your work. This project wouldn’t exist without it.
Edit: I made some progress, added some features and updated the design. See new screenshots below
Alan G
Bethesda, Maryland
Epson 3880
I've been using the Windows version of this over the past couple of days and it works quite well. I have been using Argyll for the past 15 years to do profiling for myself and others. This GUI interface streamlines things compared to pasting Notepad commands into the command line.
itsab1989
Is there anything else that is missing? In the latest 3.2.0 betas I tried to improve both printing workflows on macOS. The OS native dialog now tries to to do what the Adobe Color Print Utility does. But it never matches perfectly. ACPU locks the orinter dialog at Color Sync instead of the vendors color settings. With my ne implementation this jumps around. When I open this setting the first time it is at Color Sync the next time at the Epson settings. However in those Epson settings color management is now really disabled and locked.
itsab1989
Hmm - is late here and I need to sleep - but the bad news is that the update broke the Linux port - which previously was working OK. Note that the HOW_TO_BUILD needs updating - it still refers to the macOS commands - but notwithstanding that, I managed to get a successful build, but it wasn't a happy puppy:
_____
./ChromIQ
qt.qpa.plugin: From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: linuxfb, wayland-brcm, wayland-egl, wayland, minimalegl, minimal, vkkhrdisplay, offscreen, eglfs, xcb, vnc.
Aborted (core dumped)
_____
I'll look again tomorrow afternoon (eastern Australia time) but you may wish to chat with Claude first. Meantime, perhaps move this discussion to your ChromIQ thread.
r/
I asked Claude about it and it attempted to fix it:
https://github.com/itsab1989/ChromIQ/releases
itsab1989
So it is working now? That would be so great!
