Print layout engine for Linux. Fully ICC aware
crenedecotret
Hello,
I just wanted to make everyone aware that I created a print layout engine for Linux, similar to what's in Qimage for windows users but only with a subset of features that I needed. This is completely open source and available on github https://github.com/crenedecotret/vibeprint
Would love to hear someone comments. I've mentionned it on reddit and on pixls and I think only one person has tried it in a month
Please make sure you try plain paper before going for expensive art paper :)
Can this software also print with color management disabled for print targets ? Problem is the right linux Epson/Canon driver that can handle media types and resolution, unlike Windows/Mac drivers.
ThrillaMozilla
Sorry, I'm backlogged and can't try it right now.
But I think it's worth mentioning that the printing environment in Linux and Windows varies between passable and awful, in my opinion. The problem I have with Linux printing is an astonishing inability to print certain sizes on my Epson ET-8550. For example, I can't print 11" x 17"! On Windows one problem is the dreaded double profiling, i.e. applying an ICC profile twice. It's an unbelievable nightmare to know what your software is doing. The objection I have to QImage is that it's somewhat of a Swiss Army program. I just need something that prints and does what it's supposed to.
If your engine can handle those problems and can do basic print jobs simply and without problems and pitfalls, then I'm all in.
crenedecotret
It can but it depends on the printer.. Most guttenprint drivers have an "uncorrected" color mode. I just convert the image to the printer icc profile and send it off to CUPS (with flags to not alter the source in the process). This is similar process to what we do in windows except the operating system/driver layer is different
For some printers that don't have a guttenprint drivers, There is also a way to set the commercial turboprint driver to not do any color management
crenedecotret
Hello! The software will read the printer properties available in CUPS and present them to the user. It won't allow sizes the driver dosent know about.
I don't own an Et-8550 so I'm not sure what the driver looks like. I think that printer is not supported (yet) in guttenprint so it probably dosent have the "uncorrected" color mode that my old Epson r2000 has.
I was considering a purchase of that printer so I looked around. On Linux, by default, it works using driverless mode (airprint). This might be why you don't have a 11x17 selection. I think Epson offers a Linux driver for the et-8550 which may be better. If not, turboprint supports the printer (but it's not free). All these options can be profiled but the driverless mode won't be quite as good.
If you ever give Linux another shot, Id be happy to help if I can.
I didn't reproduce qimage.. It's quality cannot be beat but there are so many options I don't use.. I really just wanted something to layout images and print them out with output dpi and light output sharpening. The only non printing features I recreated are cropping and the ability to add inner and outer borders (black only for now)
crenedecotret
Just for the sake of transparency... This was all done with AI. Claude Opus for the heavy lifting and an open source au model for the coding.
I don't know how to code but I know about operating systems work in general (I'm a systems administrator) and know the color managed printing path on Linux quite well.
There is about 50 hours of work involved on a project like this and probably as many pages of copy paper in the recycling bin. The initial code produced by Claude had gotten so many things wrong because it thought it knew what it was doing.
I still really enjoyed the experience. It's like having a junior programmer that does a lot of mistakes. In a few cases, when mistakes were made I realized I needed to give the AI more info to begin with
ThrillaMozilla
Actually, I have the Epson driver. I can define a custom page size, 11"x17", but CUPS gives me an error message: "Custom Page Size is out of range." In fact, it isn't out of range for the printer. The setup seems to be confused between Landscape and Portrait, and that may be related to the error. Anyway, this is my problem, not yours, and I can't troubleshoot it right now.
Apparently I also have a driverless mode available, but that's probably simplistic. I also have Gutenprint available and on the print menu, but it looks rather strange. Enough for now. I just want a simple print dialog that works, and I can't afford infinite troubleshooting right now.
Thanks. I use it all the time except when I'm forced to use Windows. This is one of those times.
Thanks for writing that program. I do notice in your screenshot that you only have an option to set one margin, but there are four margins on a page.
crenedecotret
It's sort of a "base" margin that's all around the paper. I noticed most printers will have something built in. On windows my R2000 was 3mm unless it was set to borderless. On linux it defaulted to 0mm. The option is there basically to fix any driver inconsistencies. By default it will read what CUPS reports but the user can define a larger value if they want to be on the safe side.
Say you want to print 12x18 on 13x19 paper. There would be two ways to do it.. you either leave the paper as detected and select 12x18 photo size when you add it to the canvas... OR you add a 1 inch border to your 13x19 paper and select the "Fit to page" option for the image
itsab1989
Epson ET 8550, Canon Pro 300
I have been working on a GUI for the printer profiling part of ArgyllCMS and it has a tab for printing. On macOS Claude Code suggested a workflow via CUPS that we implemented. It did some research and told me that CUPS would only present the user with options that the printer really has. When I tried this with my Epson 8550 this did not work. It gave me all kinds of options and even let me combine options that would be conflicting in the real printer driver from Epson (you usually can’t choose certain quality settings for every media type e.g. draft for photo papers). I had to manually look into the driver and take notes about which combinations it supports and feed it into Claude. Then it worked. But I don’t know if it now works for every Epson printer or just the 8550? And I also don’t know how it is for printers from other manufacturers. This is really quite painful…
riclin
Melbourne, Australia
Canon Pro-10S, Canon iP8760
I strongly suggest that you examine Turboprint. A trial version is available on the zedo website.
