Epson 1500W print head replacement
brian_mk
Epson Stylus 1500W
The print head in my 1500W has the common 'black ink leaking into the adjacent yellow channel' problem (delamination) and needs to be replaced.
Has anyone carried out a print head replacement? I have watched a couple of videos and it looks feasable.
Replacement heads are available from Aliexpress for just over £100. Are they any good?
There seem to be two different part numbers available: F1730350 or R1390.
I get the impression that F1730350 is a non-original replacement.
brian_mk
Epson Stylus 1500W
After watching a video on how to repair the actual print head, I think the chances of success are slim to say the least.
It would require buying some fairly expensive special tools and equipment: A low power stereo microscope, an ultrasonic cleaning bath plus some special 2 part sealant.
Even if repair were possible, it would not be cost effective just for a single print head.
I'd rather just buy a new Canon pixma pro-200s. (UK price around £450).
Unfortunately a set of replacement 8 ink carts for the Canon costs over £100.
I still have some ink for the 1500W which is why I was considering replacing the print head. I have read a couple of reviews that suggest some of the Chinese replacements are useless and leak ink straight away.
Some years ago I used to work for Fujifilm Electronic Engineering (FFEI). They manufactured industrial inkjet printers used for packaging. They used UV curable inks and print heads made by Xaar. Each colour channel used a separate head. I seem to remember the heads required individual calibration I.e. the voltage required to generate equal size ink drops differs from head to head. I wonder if the heads used on Epson printers also require calibration during installation.
Did you ever consider trying to get a second hand Canon 100, that would be a far better choice, it would easier to run and cheaper than the pro 200..
Epson is doing something very similar - printheads of lots of printers are coded - with a kind of serial number which carries individual technical parameters which are coded with a barcode, and such barcode label is attached to the printhead. When replacing such printhead you need to enter this code of the new printhead into the printer firmware, WicReset offers you to read and replace this code in the firmware. I checked on my L805 printer which is a kind of 6 ink A4 printer similar to the 1500, and WicReset is supporting this code entry.
bplaman
Epson Stylus Photo 1500W
Hi.
I asked Grok. This is what he said.
Can I replace the print head myself on an Epson 1500W printer?
Yes, it is possible to replace the print head on the Epson Stylus Photo 1500W yourself
, but it is a quite complex and risky procedure. Many people have successfully done it (there are even videos titled “head replacement in 3 minutes”), but there are also a huge number of cases where the mainboard gets burned during the process due to mishandling the flat cables or static electricity.
Key things to know before starting​
  • Print head model — most commonly F173050 / F173060 / F173070 / F173090 (depends on the production year and region). In most cases they are interchangeable.
  • After replacement, you will almost always need to enter the Head ID (the 24-digit code from the sticker on the new head) using the service program (usually Adjustment Program for 1500W / 1400 / 1430). Without this, the printer may print very poorly — with strong blurring or severe color misalignment.
  • Main risks:
    • Burning the mainboard when connecting/disconnecting flat cables (the most common issue)
    • Damaging or incorrectly seating the cables
    • Misaligning the head position → banding, offset prints
    • Static electricity killing the electronics
Rough step-by-step (general; watch videos specifically for 1500W)
  1. Turn off the printer and unplug it from the power outlet, remove all cartridges.
  2. Remove side covers, panels, and get access to the carriage.
  3. Move the carriage to the service position (often manually or via the cartridge replacement menu + unplug the power cord at the right moment).
  4. Disconnect the flat cables (very carefully! don’t bend or pull hard).
  5. Unscrew 2–4 screws holding the head to the carriage.
  6. Carefully remove the old head.
  7. Install the new one (make sure to align the guides properly and don’t tilt it).
  8. Reconnect the flat cables (correct order and proper pressure are important).
  9. Reassemble everything in reverse order.
  10. Run the Adjustment Program → enter the new Head ID.
  11. Perform several powerful cleanings + nozzle check.
Helpful videos (search these exact titles on YouTube)
  • “Change Epson 1500w head in 3 minutes replacement”
  • “Epson 1500w head replacement and how the motherboard got burned” (very useful — shows how easy it is to burn the board and how to avoid it)
Realistic advice​
  • If you already have experience disassembling similar Epson models (R270, T50, L1800, 1390/1400 etc.) — you can try it yourself.
  • If you have little or no experience — it’s better to take it to a service center (cost of head + labor is usually around $100–200 USD in 2024–2026, depending on the region).
Good luck! If you decide to do it — please come back and tell us how it went and whether the board survived 😄
brian_mk
Epson Stylus 1500W
Where is the best place to download the Adjustment Program?
As far as I can tell it requires an activation key before you can use it (or does that only apply to the waste ink resetter function?). The activation key is not free.
Most of the download sites I have looked at also indicate the need to disable anti-virus software before running.
That seems a bit dubious.
I find it annoying that Epson do not make this adjustment software available for free. They (or someone else) are making money from a component that frequently fails.
Another reason to switch from Epson to Canon.
Update: I discovered the 'WIC Reset utility' allows the head ID to be changed without the need to buy a key. Keys are only required to reset the waste ink counter or update the printer firmware.
brian_mk
Epson Stylus 1500W
I found a F173060 print head on eBay UK for just under £70. It was described as 'opened, never used'.
When it arrived, the packaging was poor and the nozzle plate did not look clean.
On further inspection with a magnifier, the nozzles themselves did not look clean.
When I injected cleaing fluid into the ink cartridge inlet tubes, what looked like dried ink emerged from the nozzles.
I am pretty sure some of the nozzles were blocked.
The head had obviously been installed in a printer and used.
Luckily I managed to obtain a refund.
I don't trust other sellers I have found on eBay. Even the heads described as 'new' don't look clean in the photos.
Can anyone recommend a reliable supplier?
Even suppliers on Amazon UK cannot be trusted. This one gets an apalling 76% 1 star rating.
brian_mk
Epson Stylus 1500W
The print head id for an Epson 1500W is supposed to be 24 digits.
The photo shows the label on the replacement print head (F173060). It has 32 digits. What is the head id that should be entered into the adjustment program?
If I use a QR code scanner it gives the following string:-
18474788785UUUUUUT0MTSYS2NUSXVP0%....0133R.7B194N10269138BVE
brian_mk
Epson Stylus 1500W
I am pretty sure I have been sent the wrong part (ordered on eBay UK).
The original eBay description says:-
F173060 Printer Print Head Fits For Epson Stylus Photo R270 RX560 R265 R275​
However, the F173060 connectors have 9 pins & 27pins. The one I received has 13pins & 23 pins.
I think the print head I received is for an Epson L800 printer.
I found this info on the DIGIPRINT SUPPLIES website:-
The Epson L800/L801/L805/TX650/PX660 printhead is compatible with Epson L800 printers and various DTF printers. Please note that it is not interchangeable with the L1800 printhead.
This printhead part number is F180040, replacing F180000 / F180010 / F180030. The ID of printhead has 8 digits on the first line, 8 digits on the 2nd line, 8 digits on the third line, 8 digits on the 4th line and 1 digit on the 5th line. The cables that connect to this printhead have 23 pins and 13 pins.
This is what I should have received (again from the DIGIPRINT SUPPLIES website :-
It's for an L1800 but it is compatible with the F173060 head.
The Epson Stylus Photo L1800 printhead is compatible with Epson L1800, Epson Stylus Photo 1390, 1400, and 1410 printers, as well as various DTF printers. Please note that it is not interchangeable with the L800 printhead. It offers as resolution of 5760 dpi.
This printhead part number is F173090, replacing F173050 / F173060 / F173070 / F173080 / F173090. The ID of printhead has 7 digits on the first line, 7 digits on the 2nd line, 7 digits on the third line and 3 digits on the 4th line. The cables that connect to this printhead have 27 pins and 9-pins.
You can't trust supplers on eBay.
