Not sure but I think PrintPrism might work on some un-supported scanners too
I have to test this, but my first impression that by chance I tried to make a profile with PrintPrism with my unsupported Epson WF-7840 AIO scanner using the built-in ET-8550 scanning engine:
The scan histogram seems to be very healthy and this is the 3D plot in iccview.de with the same target scanned with the officially supported Et-8550 scanner (wired frame):
And this the softproofing with both profiles in PS (left with the test profile (WF-7840) and right with the profile made on the officially supported ET-8550):
Redoing the test with an earlier printed target on another paper type:
First on the ET-8550 scanner:
Secondly on the WF-7840 scanner:
Here is the iccview.de 3D plot:
Using both profiles in softproofing mode beneath: left original picture, upper right: softproofed with the ET-8550 profile (supported scanner using the dedicated ET-8550 scanning engine) and lower right: softproofed with the WF-7840 profile (unsupported scanner using the PrintPrism ET-8550 scanning engine):
below you can download both testprofiles in zip file to look at (note: this profile is not usable if you don't have combination: Netbit Glossy with the Inktec Powerchrome K3 ink (with original Epson PK en Violet ink) and the Epson SC-P900) and is only for demonstration/experiment.
  • test_profiles ET-8550 vs WF-7840.zip
As much as Epson is using the same printhead across a wide range of printers they'll use as well the
same scanning hardware across a similar range of printers. It would be just a matter of some tests - printing the patch file on several different printers by different users and comparing the outcome - how close the gamut volumes would match.
I have printed the target on a cheap cast paper of Action with the ET-8550, which should give a different 3D plot. I will redo the test this evening and see if the profile is similar using both the ET-8550 (supported) and the WF-7840 (non-supported) scanners.
OK here is the second test using a different paper/ink/printer combination: Action Glossy (cast paper) on the ET-8550 dye ink printer:
First on the dedicated and supported ET-8550 scanner:
Here is the version on the unsupported WF-7840 scanner:
Note the above bump on the right side of the scan histogram, visible in bot the ET-8550 and the WF-7840 scan.
iccview.de 3D plot:
  • test profiles Action ET-8550 vs WF-7840.zip
Softproofing with both profiles in PS (RC, BPC=on):
I printed an evaluation target using both profiles and scanned both print outs with my calibrated scanner (ET-8550):
Which on is printed with the profile created with the unsupported WF-7840 and which one with the supported ET-8550 profile ?
W. Fisher
Epsons, Canons, Brother.
ColorThink Pro 3.05 says the color gamut volume of the WF-7840 is 487,867. The supported ET-8550 is 508,861. Not a huge difference, or about 4% less for the WF-7840, and unlikely it would be seen by most people.
Epatcola
various
Gamut volume tells you little. Profiles of completely different shape could have identical gamut volumes.
Looking at the two profiles pharmacist posted the shape deviates around the edges a bit and the WF-7840 white point is significantly darker.
