Can anyone identify this part on a Laserjet 3330?
Hogwild
Canon D1350, Canon IP6600D
I thought this (black plastic) part and the stuff attached to it was the scanner assembly. However, Googling shows a very different looking part for the scanner assembly for a LJ3330.
Yes that is the inner parts of a scanner. The scanner motor and CCFL shows it is a scanner.
When looking for printer parts it is important to use the exact same wording as the manufacturer. A service manual and parts catalog is a great help.
Here is a service manual and parts list. See pages 246 and 247. It looks like the parts number is C9124-60103 Scanner assembly.
Googling "hp lj3330 scanner assembly" finds many strange things, for instance this that looks like a HDD mounting bracket to me. I think they attached a wrong image. I have also seen laser scanner unit which is the component that writes the document to the drum,
Hogwild
Thanks. I already tried that part number. No one has it in stock in the west.
Already have the service manual, thanks. I really just need to replace the mirror. But maybe if the entire assembly holding the mirror was cheap, I would've tried to get it. Looks like this is going in the garbage. <sad>
I'm going to try very hard never to break a mirror again.
Maybe you could find another HP AIO of the same vintage or some old Scanjet model? I think these were all CCD scanners so maybe a mirror could be found in one of these?
Here is a good explanation of the working of CCD and CIS scanners. The CCD drawing made me think HP probably used the same mirror in all Letter/A4 CCD scanners.
Hogwild
Thanks. Unfortunately, the site throws an "access denied" error.
Yes I see they blocked access to the site. I think I found the drawing of the CCD vs CIS scanners on Google:
"Besøg" means "Visit".
At least some of the article from the blocked site can be seen on linkedin. I don't know if that is any help?
I found out The Wayback Machine made a snapshot of the article before the access was restricted. Link here.
