- Dec 27, 2014
- Germany
There are no sponges in these cartridges; I'm using a strong and long blunt needle which I push in one of the holes to suck out the ink with a syringe, and a second needle to let air to get into it. It requires a little bit of practice.
Here is another offer - gray - 130 ml for 17,99€, but you need to monitor the availability , not all colors are available all the time; I have seen expired cartridges on Ebay Germany, Austria and the U.S but I don't know where you are . I never had problem with such inks.
https://www.ebay.de/itm/284410090239?hash=item42382992ff:g:MugAAOSwYB5hGBNy&amdata=enc:AQAHAAAAoB8XqJIdbxYFd6uh2oJiK2ljS/jvOEyU0/o/mLhTmiVGpUj4PBgzFlDq2Xxxk+dnWxN/GDSQdTUAAn1Mc/+/j8Ze8hoAKUhuNc0VrwyO/k6pzpE+E1AsjknYAFOn0tubvtf9jH5HDCL17kopKCjBpc6zEq8Mu91B9adi1akJD/UA1f2j8mITRmCRx2wPgDaRgeQ13gpqEEw8Th5BEWEC8T0=|tkp:Bk9SR7LWtfHyYA
It's the Lucia ink in this case which has been filled up in various cartridge sizes.
Yep that will work for pouring out... You do need to allow air in to allow the ink to exit though. For this I use a sharp needle with a long piece of tubing attached as a sort of vent chimney. You make sure the end of the vent tube is about a foot or more above where you'll hold the cartridge so you don't get ink pouring out of that instead of air being drawn in. Oh and the needle gets poked into the ink outlet (on PFI-706 carts they have two rubber inlet plugs that you can plunge the needle into).
