- Dec 27, 2014
- Germany
Let me adress an issue with your profile which may or may not be related to the problem in the dark blue area, there is a small inconsistency at the yellow corner
There is a irregularity at the yellow corner, the display may not match exactly the table values of the profile but I know from other similar tests that MonacoGamutWorks is more susceptible to such inconsistencies than other gamut viewers - like Gamutvision - iccview.de - barely showing anything. There is an issue with the monotony of the table data - this can have lots of different reasons - but this issue would not be visible in printouts I'm pretty sure
- it could be a scan/read error, and rescanning eliminates the kinky profile corner
- or there is a problem with the spectrometer reading wrong data - which can be caused by bronzing effects of the paper/ink combination - and the problem goes away if you change the position of the spectro slightly - tilting the spectro by a few degrees - e.g. lifting an i1Pro spectro slightly on an i1iO table. If such action gives you different scan data you are victim of a bronzing effect, it can ge worse with lustre - semiglossy like paper surfaces. XRite offers the i1Pro3 with polarized light for this reason . You may compare scan data with an I1Pro and the i1iSys scanner which may deliver different readings as well.
I was testing the effects of a gloss optimizer longer time ago - such GO takes away virtually all such bronzing effects and increases the overall gamut significantly including a better/darker black level.
This let me come to the assumption that your weak dark blue could be a problem that your spectro is measuring some bronzing light as well which distorts the profile in that range.
