- Jan 18, 2010
- Residing in Wicklow Ireland
Why is it that guys say pigment ink printers clog more than dye ink printers.
I started the switch to pigment inks more than ten years ago because of their more obvious advantages, and one was not clogging, in fact I taught I’d have more clogs with the pigment inks, which turned out to be the exact opposite.
I’ve had less issues with clogs using pigment inks than I did with dye inks, and since then have phased out all my dye ink printers in regular use, except the iP4500, which seems immune to clogging..
The one exception I had was the Maxify, it just didn’t like 3rd party inks and clogged up on a regular basics and had be cleaned a lot before use, but the same inks worked flawlessly in the Pro9500.
The older printers worked easier with 3rd party inks without issues, but there is a greater need to be careful with the newer printers, it’s too easy to damage the print head after only a couple of refills..
