- Jan 18, 2010
- Residing in Wicklow Ireland
Cartridges can be changed anytime in the Pro 1, once the ink tank door is open, when the ink tank door is requested to open the printer decreases the pressure in the system to prevent spillage.I still have original black-matte cartridge that I took out 2 weeks ago...it's not empty, should I try to reuse
You can reuse the Matte black OEM cart again and put it back into the printer and you could re-use the ink in the compatible cart to top up the OEM black cart also if you wish.
The Pro 1 can detect when your using non OEM carts and can refuse to work till they are removed, the firmware update could have increased the machines awareness of this incompatibility issue also.. this printer is very aware of everything you do..
